Nagendra Somanapalli
*** error 129: MapMem - map size truncated to 128MB
I USED STM32H747 DEV BOARD, I GOT THIS ERROR WHEN I USED TO PROGRAMM ETHERNET, GIVE ANY SOLUTION
Hello @Nagendra Somanapalli​ and welcome to the STM32 Community :)
Which IDE and firmware version are you using ?
Please provide more details about your issue and environment, so that Community users or ST employees can help you.
Imen
Can u help me sample code for STM32H747I DISCO board for ethernet communication?
Hi @Nagendra Somanapalli
Have a look at this article How to create project for STM32H7 with Ethernet and LwIP stack working.
There is a LwIP example in the STM32CubeH7 MCU package that can help you in your application:
STM32Cube_FW_H7_V1.9.0\Projects\STM32H743I-EVAL\Applications\LwIP.
You should refer to the User manual and datasheet for your board that helps you in the pin configuration.
Note that the Ethernet driver will be fully reworked for multiple fixes by 21Q2.
Imen
March 16, 2021
Look like a Keil error.
Not sure anyone is going to help unless the situation is more clearly explain
