Mar 31, 2026 11:00 UTC
EPR request in STM32G071
Hello
I have my own board with STM32G071KBT6 microcontroller. I successfully comunicate with charger by PD protocol and I receive up to 21 V (PPS). But I need above 21V. I have power bank with AVS up to 28V and USB cable with e-marker (up to 240W). How to configure the stack to receive EPR parameters? I have no TCPP IC, but I use my own protection circuit. In the trace the EPR commands isn't present. I use STM32CubeIDE 2.1.1 and STM32CubeMX 6.17.0.
Thanks a lot and best regards
Jaroslaw_TBest answer
Aug 11, 2026 10:22 UTC
Hello
I have good news - during test (with ST and AI support) I have done changes:
In stm32g0xx_it.c file in function: void TIM17_IRQHandler(void) I have added: USBPD_DPM_TimerCounter();
In case USBPD_CORE_DATATYPE_RCV_SRC_PDO_EPR:
uint8_t x=1; //hardcoded PDO EPR from source position
uint32_t EPR=0;
DPM_USER_DEBUG_TRACE(PortNum, "EPR - received: %lu bytes, %d PDOs", Size, Number_Of_EPR_PDO);
(void)memcpy(&EPR, Ptr+(x*4U), 4U);
DPM_USER_DEBUG_TRACE(PortNum, "x: %d - EPR: 0x%08lX", x, EPR);
USBPD_SRCProgrammablePowerSupplyAVSPDO_TypeDef PDO;
uint8_t src_power;
uint8_t src_max_voltage;
uint8_t src_min_voltage;
(void)memcpy(&PDO, &EPR, sizeof(PDO));
src_power = PDO.PDPIn1W;
src_min_voltage=PDO.MinVoltageIn100mV/10;
src_max_voltage=PDO.MaxVoltageIn100mV/10;
DPM_USER_DEBUG_TRACE(PortNum, "EPR: %d W, Max %d V", src_power, src_max_voltage);
if((EPR&0b11000000000000000000000000000000UL)!=0b11000000000000000000000000000000UL) //if not AVS
DPM_USER_DEBUG_TRACE(PortNum, "0x%08lX", EPR);
EPR_Voltage=(EPR>>10);
EPR_Voltage=EPR_Voltage&0b00000000000000000000001111111111;
EPR_Voltage=EPR_Voltage*50;
EPR_Current=EPR&0b00000000000000000000001111111111;
EPR_Current=EPR_Current*10; //prąd w mA
DPM_USER_DEBUG_TRACE(PortNum, "EPR = %lu mV, %lu mA", EPR_Voltage, EPR_Current);
if((EPR&0b11000000000000000000000000000000UL)==0b11000000000000000000000000000000UL) //if AVS
uint32_t Max_Voltage_100mV=(EPR>>17);
Max_Voltage_100mV = Max_Voltage_100mV&0b00000000000000000000000111111111;
DPM_USER_DEBUG_TRACE(PortNum, "EPR AVS - max voltage: %lu mV", (Max_Voltage_100mV*100));
break;
and in USBPD_DPM_SNK_EvaluateCapabilities:
USBPD_SNKRDO_TypeDef rdo;
rdo.d32=0;
DPM_USER_DEBUG_TRACE(PortNum, "AVS mode");
rdo.AVSRDO.EPR_Capable=1;
rdo.AVSRDO.ObjectPosition=9;
rdo.AVSRDO.OutputVoltageIn25mV=960; //24V
rdo.AVSRDO.OperatingCurrentIn50mAunits=100U; //5A
rdo.AVSRDO.NoUSBSuspend=0;
rdo.AVSRDO.USBCommunicationsCapable=0;
rdo.AVSRDO.CapabilityMismatch=0;
rdo.AVSRDO.Reserved1=0;
rdo.AVSRDO.Reserved2=0;
rdo.AVSRDO.Reserved3=0;
DPM_USER_DEBUG_TRACE(PortNum, "RDO after evaluation: 0x%08lX", rdo.d32);
//PDO_Parameters=rdo.d32; //for further use
//PDO_Position=rdo.AVSRDO.ObjectPosition; //for further use
*PtrPowerObjectType=USBPD_CORE_PDO_TYPE_AVSPDO;
*PtrRequestData=rdo.d32;
and trace:
CAD	503	1	USBPD_CAD_STATE_DETACHED	19720
DEBUG 505 1 ADVICE: Update BSP_USBPD_PWR_VBUSInit 19721
CAD 505 1 USBPD_CAD_STATE_ATTACHED_WAIT 19722
CAD 624 1 USBPD_CAD_STATE_ATTACHED 19723
NOTIF 624 1 USBSTACK_START 19724
DEBUG 624 1 ADVICE: USBPD_DPM_Notification:104 19725
EVENT 624 1 EVENT_ATTACHED 19726
DEBUG 624 1 ADVICE: update USBPD_DPM_UserCableDetection 19727
DEBUG 624 1 ADVICE: update USBPD_DPM_SetDataInfo:2 19728
DEBUG 624 1 ADVICE: update USBPD_DPM_SetDataInfo:6 19729
PE 625 1 PE_SNK_STARTUP 19730
PE 625 1 PE_SNK_WAIT_FOR_CAPABILITIES 19731
IN 720 1 SOP PD3 s:030 H:0x71A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21A4C1
Option: EPW DRP
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
[3] Fixed : 12V - 3A
[4] Fixed : 15V - 3A
[5] Fixed : 20V - 5A
[6] Programmable : [3.3V - 11V] - 3A
[7] Programmable : [3.3V - 21V] - 3A
19732
OUT 720 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 19733
DEBUG 720 1 Received: 28 bytes 19734
DEBUG 720 1 PDO[1] = 5000 mV, 3000 mA, 15 W 19735
DEBUG 721 1 PDO[2] = 9000 mV, 3000 mA, 27 W 19736
DEBUG 721 1 PDO[3] = 12000 mV, 3000 mA, 36 W 19737
DEBUG 721 1 PDO[4] = 15000 mV, 3000 mA, 45 W 19738
DEBUG 721 1 PDO[5] = 20000 mV, 5000 mA, 100 W 19739
DEBUG 721 1 APDO [6] - max voltage: 11000 mV 19740
DEBUG 721 1 APDO [7] - max voltage: 21000 mV 19741
PE 721 1 PE_SNK_EVALUATE_CAPABILITY 19742
DEBUG 722 1 Evaluate capabilities... 19743
DEBUG 722 1 PDO mode 19744
PE 722 1 PE_SNK_SEND_REQUEST 19745
OUT 722 1 SOP PD3 REQUEST s:006 H:0x1082 (id:0, DR:UFP, PR:SNK) DATA: F4D14751
ObjectPosition:5
GiveBack:0
CapabilityMismatch:0
USBCommunicationCapable:0
NoUSBSuspend:1
UnchunkedExtendedMessagesSupported:0
MaximumOperatingCurrent:5000mA
OperatingCurrent:5000mA 19746
IN 723 1 SOP s:002 H:0x0161 (id:0, DR:DFP, PR:SRC) GOODCRC 19747
PE 723 1 PE_SNK_SELECT_CAPABILITY 19748
IN 725 1 SOP PD3 ACCEPT s:002 H:0x03A3 (id:1, DR:DFP, PR:SRC) 19749
OUT 725 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 19750
NOTIF 726 1 POWER_STATE_CHANGE 19751
DEBUG 726 1 ADVICE: USBPD_DPM_Notification:90 19752
NOTIF 726 1 REQUEST_ACCEPTED 19753
DEBUG 726 1 ADVICE: USBPD_DPM_Notification:1 19754
PE 726 1 PE_SNK_TRANSITION_SNK 19755
IN 1022 1 SOP PD3 PS_RDY s:002 H:0x05A6 (id:2, DR:DFP, PR:SRC) 19756
OUT 1022 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 19757
NOTIF 1022 1 POWER_STATE_CHANGE 19758
DEBUG 1022 1 ADVICE: USBPD_DPM_Notification:90 19759
NOTIF 1023 1 POWER_EXPLICIT_CONTRACT 19760
DEBUG 1023 1 USB voltage: 20133 mV 19761
PE 1023 1 PE_STATE_READY 19762
NOTIF 1023 1 STATE_SNK_READY 19763
DEBUG 1023 1 ADVICE: USBPD_DPM_Notification:32 19764
PE 1023 1 PE_STATE_SEND_EPRMODE 19765
DEBUG 1023 1 ADVICE: update USBPD_DPM_GetDataInfo:30 19766
OUT 1023 1 SOP s:006 PD3 H:0x128A (id:1, DR:UFP, PR:SNK) EPR_MODE
EPR_MODE : 01000000
Action: 01
0x01 Enter Sink only
0x02 Enter Acknowledged Source only
0x03 Enter Succeeded Source only
0x04 Enter Failed Source only
0x05 Exit Sink or Source
Data: 00
0x00 - Unknown cause
0x01 - Cable not EPR capable
0x02 - Source failed to become VCONN source
0x03 - EPR Mode Capable bit not set in RDO
0x04 - Source unable to enter EPR Mode at this time
0x05 - EPR Mode Capable bit not set in PDO
19767
IN 1024 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 19768
PE 1024 1 PE_STATE_WAIT_EPRMODE_ACK 19769
IN 1025 1 SOP s:006 PD3 H:0x17AA (id:3, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 02000000
Action: 02
Data: 00
19770
OUT 1025 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 19771
DEBUG 1026 1 ADVICE: update USBPD_DPM_SetDataInfo:23 19772
NOTIF 1026 1 NOTIFY_EPRMODE_ACK 19773
DEBUG 1026 1 ADVICE: USBPD_DPM_Notification:113 19774
IN 1041 1 SOP s:006 PD3 H:0x11AA (id:0, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 03000000
Action: 03
Data: 00
19775
OUT 1041 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 19776
PE 1042 1 PE_STATE_WAIT_EPRMODE_STATUS 19777
DEBUG 1042 1 ADVICE: update USBPD_DPM_SetDataInfo:23 19778
NOTIF 1042 1 NOTIFY_EPRMODE_SUCCEEDED 19779
DEBUG 1042 1 ADVICE: USBPD_DPM_Notification:114 19780
PE 1042 1 PE_SNK_WAIT_FOR_CAPABILITIES 19781
IN 1044 1 SOP s:030 PD3 H:0xF3B1 (id:1, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu0Ch1CReq0DSiz32 [ CHUNK BEGIN ] DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21 19782
OUT 1044 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 19783
OUT 1045 1 SOP s:006 PD3 H:0x9491 (id:2, DR:UFP, PR:SNK) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq1DSiz0 DATA: 0000 19784
IN 1047 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 19785
IN 1049 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ]
EPR SOURCE CAPA
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
[6] EPR : [11V - 3.3V] - 60W
[7] EPR : [21V - 3.3V] - 60W
[8] Fixed : 28V - 5A
[9] EPR : [28V - 15V] - 140W
DATA: A4C1F4C188008C9630D2 19786
OUT 1049 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 19787
DEBUG 1049 1 Received: 28 bytes 19788
DEBUG 1050 1 PDO[1] = 5000 mV, 3000 mA, 15 W 19789
DEBUG 1050 1 PDO[2] = 9000 mV, 3000 mA, 27 W 19790
DEBUG 1050 1 PDO[3] = 12000 mV, 3000 mA, 36 W 19791
DEBUG 1050 1 PDO[4] = 15000 mV, 3000 mA, 45 W 19792
DEBUG 1050 1 PDO[5] = 20000 mV, 5000 mA, 100 W 19793
DEBUG 1050 1 APDO [6] - max voltage: 11000 mV 19794
DEBUG 1050 1 APDO [7] - max voltage: 21000 mV 19795
DEBUG 1051 1 EPR - received: 4 bytes, 1 PDOs 19796
DEBUG 1051 1 x: 1 - EPR: 0xD230968C 19797
DEBUG 1051 1 EPR: 140 W, Max 28 V 19798
DEBUG 1051 1 0xD230968C 19799
DEBUG 1051 1 EPR AVS - max voltage: 28000 mV 19800
PE 1051 1 PE_SNK_EVALUATE_CAPABILITY 19801
DEBUG 1052 1 Evaluate capabilities... 19802
DEBUG 1052 1 AVS mode 19803
DEBUG 1052 1 RDO after evaluation: 0x90478064 19804
PE 1052 1 PE_SNK_SEND_REQUEST 19805
OUT 1052 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: 648047908C9630D2
ObjectPosition:1
GiveBack:0
NoUSBSuspend:0
MaximumOperatingCurrent:1000mA
OperatingCurrent:4800mA 19806
IN 1053 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 19807
PE 1053 1 PE_SNK_SELECT_CAPABILITY 19808
IN 1055 1 SOP PD3 ACCEPT s:002 H:0x07A3 (id:3, DR:DFP, PR:SRC) 19809
OUT 1055 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 19810
NOTIF 1056 1 POWER_STATE_CHANGE 19811
DEBUG 1056 1 ADVICE: USBPD_DPM_Notification:90 19812
NOTIF 1056 1 REQUEST_ACCEPTED 19813
DEBUG 1056 1 ADVICE: USBPD_DPM_Notification:1 19814
PE 1056 1 PE_SNK_TRANSITION_SNK 19815
IN 1350 1 SOP PD3 PS_RDY s:002 H:0x09A6 (id:4, DR:DFP, PR:SRC) 19816
OUT 1350 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 19817
NOTIF 1351 1 POWER_STATE_CHANGE 19818
DEBUG 1351 1 ADVICE: USBPD_DPM_Notification:90 19819
NOTIF 1351 1 POWER_EXPLICIT_CONTRACT 19820
DEBUG 1351 1 USB voltage: 24119 mV 19821
PE 1351 1 PE_STATE_READY 19822
NOTIF 1351 1 STATE_SNK_READY 19823
DEBUG 1351 1 ADVICE: USBPD_DPM_Notification:32 19824
PE 1351 1 PE_STATE_READY_WAIT 19825
NOTIF 1725 1 ERROR with Trace_Notif :78 19826
DEBUG 1725 1 ADVICE: USBPD_DPM_Notification:120 19827
PE 1826 1 PE_STATE_SEND_EPRKEEPALIVE 19828
DEBUG 1826 1 INIT CHUNK 19829
DEBUG 1826 1 SEND UNCHUNK 19830
IN 1827 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 19831
OUT 1828 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 19832
PE 1828 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19833
PE 1828 1 PE_STATE_READY 19834
NOTIF 1830 1 STATE_SNK_READY 19835
DEBUG 1830 1 ADVICE: USBPD_DPM_Notification:32 19836
PE 1830 1 PE_STATE_READY_WAIT 19837
PE 2305 1 PE_STATE_SEND_EPRKEEPALIVE 19838
DEBUG 2305 1 INIT CHUNK 19839
DEBUG 2305 1 SEND UNCHUNK 19840
IN 2306 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 19841
OUT 2307 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 19842
PE 2307 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19843
PE 2307 1 PE_STATE_READY 19844
NOTIF 2309 1 STATE_SNK_READY 19845
DEBUG 2309 1 ADVICE: USBPD_DPM_Notification:32 19846
PE 2309 1 PE_STATE_READY_WAIT 19847
PE 2784 1 PE_STATE_SEND_EPRKEEPALIVE 19848
DEBUG 2784 1 INIT CHUNK 19849
DEBUG 2784 1 SEND UNCHUNK 19850
IN 2785 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 19851
OUT 2786 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 19852
PE 2786 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19853
PE 2786 1 PE_STATE_READY 19854
NOTIF 2788 1 STATE_SNK_READY 19855
DEBUG 2788 1 ADVICE: USBPD_DPM_Notification:32 19856
PE 2788 1 PE_STATE_READY_WAIT 19857
PE 3263 1 PE_STATE_SEND_EPRKEEPALIVE 19858
DEBUG 3263 1 INIT CHUNK 19859
DEBUG 3263 1 SEND UNCHUNK 19860
IN 3264 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 19861
OUT 3265 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 19862
PE 3266 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19863
PE 3266 1 PE_STATE_READY 19864
NOTIF 3267 1 STATE_SNK_READY 19865
DEBUG 3267 1 ADVICE: USBPD_DPM_Notification:32 19866
PE 3267 1 PE_STATE_READY_WAIT 19867
PE 3742 1 PE_STATE_SEND_EPRKEEPALIVE 19868
DEBUG 3742 1 INIT CHUNK 19869
DEBUG 3742 1 SEND UNCHUNK 19870
IN 3743 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 19871
OUT 3744 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 19872
PE 3744 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19873
PE 3744 1 PE_STATE_READY 19874
NOTIF 3746 1 STATE_SNK_READY 19875
DEBUG 3746 1 ADVICE: USBPD_DPM_Notification:32 19876
PE 3746 1 PE_STATE_READY_WAIT 19877
PE 4221 1 PE_STATE_SEND_EPRKEEPALIVE 19878
DEBUG 4221 1 INIT CHUNK 19879
DEBUG 4221 1 SEND UNCHUNK 19880
IN 4222 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 19881
OUT 4223 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 19882
PE 4224 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19883
PE 4224 1 PE_STATE_READY 19884
NOTIF 4225 1 STATE_SNK_READY 19885
DEBUG 4225 1 ADVICE: USBPD_DPM_Notification:32 19886
PE 4225 1 PE_STATE_READY_WAIT 19887
PE 4700 1 PE_STATE_SEND_EPRKEEPALIVE 19888
DEBUG 4700 1 INIT CHUNK 19889
DEBUG 4700 1 SEND UNCHUNK 19890
IN 4701 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 19891
OUT 4702 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 19892
PE 4703 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19893
PE 4703 1 PE_STATE_READY 19894
NOTIF 4704 1 STATE_SNK_READY 19895
DEBUG 4704 1 ADVICE: USBPD_DPM_Notification:32 19896
PE 4704 1 PE_STATE_READY_WAIT 19897
PE 5179 1 PE_STATE_SEND_EPRKEEPALIVE 19898
DEBUG 5179 1 INIT CHUNK 19899
DEBUG 5179 1 SEND UNCHUNK 19900
IN 5180 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 19901
OUT 5181 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 19902
PE 5182 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19903
PE 5182 1 PE_STATE_READY 19904
NOTIF 5183 1 STATE_SNK_READY 19905
DEBUG 5183 1 ADVICE: USBPD_DPM_Notification:32 19906
PE 5183 1 PE_STATE_READY_WAIT 19907
PE 5658 1 PE_STATE_SEND_EPRKEEPALIVE 19908
DEBUG 5658 1 INIT CHUNK 19909
DEBUG 5658 1 SEND UNCHUNK 19910
IN 5659 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 19911
OUT 5660 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 19912
PE 5661 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19913
PE 5661 1 PE_STATE_READY 19914
NOTIF 5662 1 STATE_SNK_READY 19915
DEBUG 5662 1 ADVICE: USBPD_DPM_Notification:32 19916
PE 5662 1 PE_STATE_READY_WAIT 19917
PE 6137 1 PE_STATE_SEND_EPRKEEPALIVE 19918
DEBUG 6137 1 INIT CHUNK 19919
DEBUG 6137 1 SEND UNCHUNK 19920
IN 6138 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 19921
OUT 6139 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 19922
PE 6140 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19923
PE 6140 1 PE_STATE_READY 19924
NOTIF 6141 1 STATE_SNK_READY 19925
DEBUG 6141 1 ADVICE: USBPD_DPM_Notification:32 19926
PE 6141 1 PE_STATE_READY_WAIT 19927
PE 6616 1 PE_STATE_SEND_EPRKEEPALIVE 19928
DEBUG 6616 1 INIT CHUNK 19929
DEBUG 6616 1 SEND UNCHUNK 19930
IN 6617 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 19931
OUT 6618 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 19932
PE 6619 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19933
PE 6619 1 PE_STATE_READY 19934
NOTIF 6620 1 STATE_SNK_READY 19935
DEBUG 6620 1 ADVICE: USBPD_DPM_Notification:32 19936
PE 6620 1 PE_STATE_READY_WAIT 19937
PE 7095 1 PE_STATE_SEND_EPRKEEPALIVE 19938
DEBUG 7095 1 INIT CHUNK 19939
DEBUG 7095 1 SEND UNCHUNK 19940
IN 7096 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 19941
OUT 7097 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 19942
PE 7097 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19943
PE 7098 1 PE_STATE_READY 19944
NOTIF 7099 1 STATE_SNK_READY 19945
DEBUG 7099 1 ADVICE: USBPD_DPM_Notification:32 19946
PE 7099 1 PE_STATE_READY_WAIT 19947
PE 7574 1 PE_STATE_SEND_EPRKEEPALIVE 19948
DEBUG 7574 1 INIT CHUNK 19949
DEBUG 7574 1 SEND UNCHUNK 19950
IN 7575 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 19951
OUT 7576 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 19952
PE 7576 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19953
PE 7576 1 PE_STATE_READY 19954
NOTIF 7578 1 STATE_SNK_READY 19955
DEBUG 7578 1 ADVICE: USBPD_DPM_Notification:32 19956
PE 7578 1 PE_STATE_READY_WAIT 19957
PE 8053 1 PE_STATE_SEND_EPRKEEPALIVE 19958
DEBUG 8053 1 INIT CHUNK 19959
DEBUG 8053 1 SEND UNCHUNK 19960
IN 8054 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 19961
OUT 8055 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 19962
PE 8056 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19963
PE 8056 1 PE_STATE_READY 19964
NOTIF 8057 1 STATE_SNK_READY 19965
DEBUG 8057 1 ADVICE: USBPD_DPM_Notification:32 19966
PE 8057 1 PE_STATE_READY_WAIT 19967
PE 8532 1 PE_STATE_SEND_EPRKEEPALIVE 19968
DEBUG 8532 1 INIT CHUNK 19969
DEBUG 8532 1 SEND UNCHUNK 19970
IN 8533 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 19971
OUT 8534 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 19972
PE 8534 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19973
PE 8535 1 PE_STATE_READY 19974
NOTIF 8536 1 STATE_SNK_READY 19975
DEBUG 8536 1 ADVICE: USBPD_DPM_Notification:32 19976
PE 8536 1 PE_STATE_READY_WAIT 19977
PE 9011 1 PE_STATE_SEND_EPRKEEPALIVE 19978
DEBUG 9011 1 INIT CHUNK 19979
DEBUG 9011 1 SEND UNCHUNK 19980
IN 9012 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 19981
OUT 9013 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 19982
PE 9014 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19983
PE 9014 1 PE_STATE_READY 19984
NOTIF 9015 1 STATE_SNK_READY 19985
DEBUG 9015 1 ADVICE: USBPD_DPM_Notification:32 19986
PE 9015 1 PE_STATE_READY_WAIT 19987
PE 9490 1 PE_STATE_SEND_EPRKEEPALIVE 19988
DEBUG 9490 1 INIT CHUNK 19989
DEBUG 9490 1 SEND UNCHUNK 19990
IN 9491 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 19991
OUT 9492 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 19992
PE 9492 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 19993
PE 9492 1 PE_STATE_READY 19994
NOTIF 9494 1 STATE_SNK_READY 19995
DEBUG 9494 1 ADVICE: USBPD_DPM_Notification:32 19996
PE 9494 1 PE_STATE_READY_WAIT 19997
PE 9969 1 PE_STATE_SEND_EPRKEEPALIVE 19998
DEBUG 9969 1 INIT CHUNK 19999
DEBUG 9969 1 SEND UNCHUNK 20000
IN 9970 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 20001
OUT 9971 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 20002
PE 9971 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20003
PE 9971 1 PE_STATE_READY 20004
NOTIF 9973 1 STATE_SNK_READY 20005
DEBUG 9973 1 ADVICE: USBPD_DPM_Notification:32 20006
PE 9973 1 PE_STATE_READY_WAIT 20007
PE 10448 1 PE_STATE_SEND_EPRKEEPALIVE 20008
DEBUG 10448 1 INIT CHUNK 20009
DEBUG 10448 1 SEND UNCHUNK 20010
IN 10449 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 20011
OUT 10450 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 20012
PE 10451 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20013
PE 10451 1 PE_STATE_READY 20014
NOTIF 10452 1 STATE_SNK_READY 20015
DEBUG 10452 1 ADVICE: USBPD_DPM_Notification:32 20016
PE 10452 1 PE_STATE_READY_WAIT 20017
PE 10927 1 PE_STATE_SEND_EPRKEEPALIVE 20018
DEBUG 10927 1 INIT CHUNK 20019
DEBUG 10927 1 SEND UNCHUNK 20020
IN 10928 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 20021
OUT 10929 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 20022
PE 10930 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20023
PE 10930 1 PE_STATE_READY 20024
NOTIF 10931 1 STATE_SNK_READY 20025
DEBUG 10931 1 ADVICE: USBPD_DPM_Notification:32 20026
PE 10931 1 PE_STATE_READY_WAIT 20027
PE 11406 1 PE_STATE_SEND_EPRKEEPALIVE 20028
DEBUG 11406 1 INIT CHUNK 20029
DEBUG 11406 1 SEND UNCHUNK 20030
IN 11407 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 20031
OUT 11408 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 20032
PE 11409 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20033
PE 11409 1 PE_STATE_READY 20034
NOTIF 11410 1 STATE_SNK_READY 20035
DEBUG 11410 1 ADVICE: USBPD_DPM_Notification:32 20036
PE 11410 1 PE_STATE_READY_WAIT 20037
PE 11885 1 PE_STATE_SEND_EPRKEEPALIVE 20038
DEBUG 11885 1 INIT CHUNK 20039
DEBUG 11885 1 SEND UNCHUNK 20040
IN 11886 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 20041
OUT 11887 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 20042
PE 11888 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20043
PE 11888 1 PE_STATE_READY 20044
NOTIF 11889 1 STATE_SNK_READY 20045
DEBUG 11889 1 ADVICE: USBPD_DPM_Notification:32 20046
PE 11889 1 PE_STATE_READY_WAIT 20047
PE 12364 1 PE_STATE_SEND_EPRKEEPALIVE 20048
DEBUG 12364 1 INIT CHUNK 20049
DEBUG 12364 1 SEND UNCHUNK 20050
IN 12365 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 20051
OUT 12366 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 20052
PE 12366 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20053
PE 12367 1 PE_STATE_READY 20054
NOTIF 12368 1 STATE_SNK_READY 20055
DEBUG 12368 1 ADVICE: USBPD_DPM_Notification:32 20056
PE 12368 1 PE_STATE_READY_WAIT 20057
PE 12843 1 PE_STATE_SEND_EPRKEEPALIVE 20058
DEBUG 12843 1 INIT CHUNK 20059
DEBUG 12843 1 SEND UNCHUNK 20060
IN 12844 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 20061
OUT 12845 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 20062
PE 12845 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20063
PE 12845 1 PE_STATE_READY 20064
NOTIF 12847 1 STATE_SNK_READY 20065
DEBUG 12847 1 ADVICE: USBPD_DPM_Notification:32 20066
PE 12847 1 PE_STATE_READY_WAIT 20067
PE 13322 1 PE_STATE_SEND_EPRKEEPALIVE 20068
DEBUG 13322 1 INIT CHUNK 20069
DEBUG 13322 1 SEND UNCHUNK 20070
IN 13323 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 20071
OUT 13324 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 20072
PE 13324 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20073
PE 13324 1 PE_STATE_READY 20074
NOTIF 13326 1 STATE_SNK_READY 20075
DEBUG 13326 1 ADVICE: USBPD_DPM_Notification:32 20076
PE 13326 1 PE_STATE_READY_WAIT 20077
PE 13801 1 PE_STATE_SEND_EPRKEEPALIVE 20078
DEBUG 13801 1 INIT CHUNK 20079
DEBUG 13801 1 SEND UNCHUNK 20080
IN 13802 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 20081
OUT 13803 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 20082
PE 13803 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20083
PE 13803 1 PE_STATE_READY 20084
NOTIF 13805 1 STATE_SNK_READY 20085
DEBUG 13805 1 ADVICE: USBPD_DPM_Notification:32 20086
PE 13805 1 PE_STATE_READY_WAIT 20087
PE 14280 1 PE_STATE_SEND_EPRKEEPALIVE 20088
DEBUG 14280 1 INIT CHUNK 20089
DEBUG 14280 1 SEND UNCHUNK 20090
IN 14281 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 20091
OUT 14282 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 20092
PE 14283 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20093
PE 14283 1 PE_STATE_READY 20094
NOTIF 14284 1 STATE_SNK_READY 20095
DEBUG 14284 1 ADVICE: USBPD_DPM_Notification:32 20096
PE 14284 1 PE_STATE_READY_WAIT 20097
PE 14759 1 PE_STATE_SEND_EPRKEEPALIVE 20098
DEBUG 14759 1 INIT CHUNK 20099
DEBUG 14759 1 SEND UNCHUNK 20100
IN 14760 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 20101
OUT 14761 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 20102
PE 14761 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20103
PE 14761 1 PE_STATE_READY 20104
NOTIF 14763 1 STATE_SNK_READY 20105
DEBUG 14763 1 ADVICE: USBPD_DPM_Notification:32 20106
PE 14763 1 PE_STATE_READY_WAIT 20107
PE 15238 1 PE_STATE_SEND_EPRKEEPALIVE 20108
DEBUG 15238 1 INIT CHUNK 20109
DEBUG 15238 1 SEND UNCHUNK 20110
IN 15239 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 20111
OUT 15240 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 20112
PE 15241 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20113
PE 15241 1 PE_STATE_READY 20114
NOTIF 15242 1 STATE_SNK_READY 20115
DEBUG 15242 1 ADVICE: USBPD_DPM_Notification:32 20116
PE 15242 1 PE_STATE_READY_WAIT 20117
PE 15717 1 PE_STATE_SEND_EPRKEEPALIVE 20118
DEBUG 15717 1 INIT CHUNK 20119
DEBUG 15717 1 SEND UNCHUNK 20120
IN 15718 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 20121
OUT 15719 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 20122
PE 15720 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20123
PE 15720 1 PE_STATE_READY 20124
NOTIF 15721 1 STATE_SNK_READY 20125
DEBUG 15721 1 ADVICE: USBPD_DPM_Notification:32 20126
PE 15721 1 PE_STATE_READY_WAIT 20127
PE 16196 1 PE_STATE_SEND_EPRKEEPALIVE 20128
DEBUG 16196 1 INIT CHUNK 20129
DEBUG 16196 1 SEND UNCHUNK 20130
IN 16197 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 20131
OUT 16198 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 20132
PE 16199 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20133
PE 16199 1 PE_STATE_READY 20134
NOTIF 16200 1 STATE_SNK_READY 20135
DEBUG 16200 1 ADVICE: USBPD_DPM_Notification:32 20136
PE 16200 1 PE_STATE_READY_WAIT 20137
PE 16675 1 PE_STATE_SEND_EPRKEEPALIVE 20138
DEBUG 16675 1 INIT CHUNK 20139
DEBUG 16675 1 SEND UNCHUNK 20140
IN 16676 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 20141
OUT 16677 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 20142
PE 16677 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20143
PE 16677 1 PE_STATE_READY 20144
NOTIF 16679 1 STATE_SNK_READY 20145
DEBUG 16679 1 ADVICE: USBPD_DPM_Notification:32 20146
PE 16679 1 PE_STATE_READY_WAIT 20147
PE 17154 1 PE_STATE_SEND_EPRKEEPALIVE 20148
DEBUG 17154 1 INIT CHUNK 20149
DEBUG 17154 1 SEND UNCHUNK 20150
IN 17155 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 20151
OUT 17156 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 20152
PE 17156 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20153
PE 17156 1 PE_STATE_READY 20154
NOTIF 17158 1 STATE_SNK_READY 20155
DEBUG 17158 1 ADVICE: USBPD_DPM_Notification:32 20156
PE 17158 1 PE_STATE_READY_WAIT 20157
PE 17633 1 PE_STATE_SEND_EPRKEEPALIVE 20158
DEBUG 17633 1 INIT CHUNK 20159
DEBUG 17633 1 SEND UNCHUNK 20160
IN 17634 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 20161
OUT 17635 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 20162
PE 17635 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20163
PE 17635 1 PE_STATE_READY 20164
NOTIF 17637 1 STATE_SNK_READY 20165
DEBUG 17637 1 ADVICE: USBPD_DPM_Notification:32 20166
PE 17637 1 PE_STATE_READY_WAIT 20167
PE 18112 1 PE_STATE_SEND_EPRKEEPALIVE 20168
DEBUG 18112 1 INIT CHUNK 20169
DEBUG 18112 1 SEND UNCHUNK 20170
IN 18113 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 20171
OUT 18114 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 20172
PE 18114 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20173
PE 18114 1 PE_STATE_READY 20174
NOTIF 18116 1 STATE_SNK_READY 20175
DEBUG 18116 1 ADVICE: USBPD_DPM_Notification:32 20176
PE 18116 1 PE_STATE_READY_WAIT 20177
PE 18591 1 PE_STATE_SEND_EPRKEEPALIVE 20178
DEBUG 18591 1 INIT CHUNK 20179
DEBUG 18591 1 SEND UNCHUNK 20180
IN 18592 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 20181
OUT 18593 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 20182
PE 18594 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20183
PE 18594 1 PE_STATE_READY 20184
NOTIF 18595 1 STATE_SNK_READY 20185
DEBUG 18595 1 ADVICE: USBPD_DPM_Notification:32 20186
PE 18595 1 PE_STATE_READY_WAIT 20187
PE 19070 1 PE_STATE_SEND_EPRKEEPALIVE 20188
DEBUG 19070 1 INIT CHUNK 20189
DEBUG 19070 1 SEND UNCHUNK 20190
IN 19071 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 20191
OUT 19072 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 20192
PE 19073 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20193
PE 19073 1 PE_STATE_READY 20194
NOTIF 19074 1 STATE_SNK_READY 20195
DEBUG 19074 1 ADVICE: USBPD_DPM_Notification:32 20196
PE 19074 1 PE_STATE_READY_WAIT 20197
PE 19549 1 PE_STATE_SEND_EPRKEEPALIVE 20198
DEBUG 19549 1 INIT CHUNK 20199
DEBUG 19549 1 SEND UNCHUNK 20200
IN 19550 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 20201
OUT 19551 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 20202
PE 19552 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20203
PE 19552 1 PE_STATE_READY 20204
NOTIF 19553 1 STATE_SNK_READY 20205
DEBUG 19553 1 ADVICE: USBPD_DPM_Notification:32 20206
PE 19553 1 PE_STATE_READY_WAIT 20207
PE 20028 1 PE_STATE_SEND_EPRKEEPALIVE 20208
DEBUG 20028 1 INIT CHUNK 20209
DEBUG 20028 1 SEND UNCHUNK 20210
IN 20029 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 20211
OUT 20030 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 20212
PE 20031 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20213
PE 20031 1 PE_STATE_READY 20214
NOTIF 20032 1 STATE_SNK_READY 20215
DEBUG 20032 1 ADVICE: USBPD_DPM_Notification:32 20216
PE 20032 1 PE_STATE_READY_WAIT 20217
PE 20507 1 PE_STATE_SEND_EPRKEEPALIVE 20218
DEBUG 20507 1 INIT CHUNK 20219
DEBUG 20507 1 SEND UNCHUNK 20220
IN 20508 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 20221
OUT 20509 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 20222
PE 20509 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20223
PE 20509 1 PE_STATE_READY 20224
NOTIF 20511 1 STATE_SNK_READY 20225
DEBUG 20511 1 ADVICE: USBPD_DPM_Notification:32 20226
PE 20511 1 PE_STATE_READY_WAIT 20227
PE 20986 1 PE_STATE_SEND_EPRKEEPALIVE 20228
DEBUG 20986 1 INIT CHUNK 20229
DEBUG 20986 1 SEND UNCHUNK 20230
IN 20987 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 20231
OUT 20988 1 SOP s:002 H:0x0A81 (id:5, DR:UFP, PR:SNK) GOODCRC 20232
PE 20989 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20233
PE 20989 1 PE_STATE_READY 20234
NOTIF 20990 1 STATE_SNK_READY 20235
DEBUG 20990 1 ADVICE: USBPD_DPM_Notification:32 20236
PE 20990 1 PE_STATE_READY_WAIT 20237
PE 21465 1 PE_STATE_SEND_EPRKEEPALIVE 20238
DEBUG 21465 1 INIT CHUNK 20239
DEBUG 21465 1 SEND UNCHUNK 20240
IN 21466 1 SOP s:002 H:0x0BA1 (id:5, DR:DFP, PR:SRC) GOODCRC 20241
OUT 21467 1 SOP s:002 H:0x0C81 (id:6, DR:UFP, PR:SNK) GOODCRC 20242
PE 21467 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20243
PE 21467 1 PE_STATE_READY 20244
NOTIF 21469 1 STATE_SNK_READY 20245
DEBUG 21469 1 ADVICE: USBPD_DPM_Notification:32 20246
PE 21469 1 PE_STATE_READY_WAIT 20247
PE 21944 1 PE_STATE_SEND_EPRKEEPALIVE 20248
DEBUG 21944 1 INIT CHUNK 20249
DEBUG 21944 1 SEND UNCHUNK 20250
IN 21945 1 SOP s:002 H:0x0DA1 (id:6, DR:DFP, PR:SRC) GOODCRC 20251
OUT 21946 1 SOP s:002 H:0x0E81 (id:7, DR:UFP, PR:SNK) GOODCRC 20252
PE 21946 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20253
PE 21946 1 PE_STATE_READY 20254
NOTIF 21948 1 STATE_SNK_READY 20255
DEBUG 21948 1 ADVICE: USBPD_DPM_Notification:32 20256
PE 21948 1 PE_STATE_READY_WAIT 20257
PE 22423 1 PE_STATE_SEND_EPRKEEPALIVE 20258
DEBUG 22423 1 INIT CHUNK 20259
DEBUG 22423 1 SEND UNCHUNK 20260
IN 22424 1 SOP s:002 H:0x0FA1 (id:7, DR:DFP, PR:SRC) GOODCRC 20261
OUT 22425 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 20262
PE 22426 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20263
PE 22426 1 PE_STATE_READY 20264
NOTIF 22427 1 STATE_SNK_READY 20265
DEBUG 22427 1 ADVICE: USBPD_DPM_Notification:32 20266
PE 22427 1 PE_STATE_READY_WAIT 20267
PE 22902 1 PE_STATE_SEND_EPRKEEPALIVE 20268
DEBUG 22902 1 INIT CHUNK 20269
DEBUG 22902 1 SEND UNCHUNK 20270
IN 22903 1 SOP s:002 H:0x01A1 (id:0, DR:DFP, PR:SRC) GOODCRC 20271
OUT 22904 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 20272
PE 22905 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20273
PE 22905 1 PE_STATE_READY 20274
NOTIF 22906 1 STATE_SNK_READY 20275
DEBUG 22906 1 ADVICE: USBPD_DPM_Notification:32 20276
PE 22906 1 PE_STATE_READY_WAIT 20277
PE 23381 1 PE_STATE_SEND_EPRKEEPALIVE 20278
DEBUG 23381 1 INIT CHUNK 20279
DEBUG 23381 1 SEND UNCHUNK 20280
IN 23382 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 20281
OUT 23383 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 20282
PE 23384 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20283
PE 23384 1 PE_STATE_READY 20284
NOTIF 23385 1 STATE_SNK_READY 20285
DEBUG 23385 1 ADVICE: USBPD_DPM_Notification:32 20286
PE 23385 1 PE_STATE_READY_WAIT 20287
PE 23860 1 PE_STATE_SEND_EPRKEEPALIVE 20288
DEBUG 23860 1 INIT CHUNK 20289
DEBUG 23860 1 SEND UNCHUNK 20290
IN 23861 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 20291
OUT 23862 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 20292
PE 23863 1 PE_STATE_WAIT_EPRKEEPALIVE_ACK 20293
PE 23863 1 PE_STATE_READY 20294
NOTIF 23864 1 STATE_SNK_READY 20295
DEBUG 23864 1 ADVICE: USBPD_DPM_Notification:32 20296
PE 23864 1 PE_STATE_READY_WAIT 20297
The EPR contract is OK, I have no reset and voltage 24V from source:-)
Thank You all
Best regards
Jaroslaw
Jul 23, 2026 08:44 UTC
Hello again.
After some test I have in USBPD_DPM_SNK_EvaluateCapabilities:
if(If_EPR==0)
rdo.d32=0;
DPM_USER_DEBUG_TRACE(PortNum, "PDO mode");
rdo.FixedVariableRDO.EPR_Capable=1U;
rdo.FixedVariableRDO.ObjectPosition=Fallback_PDO;
rdo.FixedVariableRDO.MaxOperatingCurrent10mAunits=Fallback_Current;
rdo.FixedVariableRDO.OperatingCurrentIn10mAunits=Fallback_Current;
rdo.FixedVariableRDO.USBCommunicationsCapable=USBPD_DISABLE;
rdo.FixedVariableRDO.NoUSBSuspend=USBPD_ENABLE;
rdo.FixedVariableRDO.CapabilityMismatch=USBPD_DISABLE;
*PtrPowerObjectType=USBPD_CORE_PDO_TYPE_FIXED;
PDO_Position=rdo.ProgRDO.ObjectPosition; //for further use
else //if If_EPR == 1
rdo.d32=0;
rdo.AVSRDO.EPR_Capable=1U;
rdo.AVSRDO.ObjectPosition=9U;
rdo.AVSRDO.NoUSBSuspend=USBPD_ENABLE;
rdo.AVSRDO.USBCommunicationsCapable=USBPD_DISABLE;
static_RDO=rdo; //for further use
DPM_USER_DEBUG_TRACE(PortNum, "RDO after evaluation = 0x%08lX", rdo.d32);
DPM_USER_DEBUG_TRACE(PortNum, "static_RDO.d32: 0x%08lX", static_RDO.d32);
DPM_USER_DEBUG_TRACE(PortNum, "Position: %d", static_RDO.AVSRDO.ObjectPosition);
DPM_USER_DEBUG_TRACE(PortNum, "Voltage: %d", static_RDO.AVSRDO.OutputVoltageIn25mV);
static_Power_Object_Type=*PtrPowerObjectType; //for further use
USBPD_StatusTypeDef status=USBPD_PE_Send_Request(PortNum, rdo.d32, USBPD_CORE_PDO_TYPE_AVSPDO);
if(status!=USBPD_OK)
DPM_USER_DEBUG_TRACE(PortNum, "USBPD_PE_Send_Request failed");
and in USBPD_DPM_GetDataInfo:
case USBPD_CORE_DATATYPE_REQ_COPYPDO:
if(static_Power_Object_Type==USBPD_CORE_PDO_TYPE_AVSPDO)
*Size=0;
DPM_USER_DEBUG_TRACE(PortNum, "Direct sent of AVSPDO");
break;
My trace:
CAD	503	1	USBPD_CAD_STATE_DETACHED	990
DEBUG 505 1 ADVICE: Update BSP_USBPD_PWR_VBUSInit 991
CAD 505 1 USBPD_CAD_STATE_ATTACHED_WAIT 992
CAD 625 1 USBPD_CAD_STATE_ATTACHED 993
NOTIF 625 1 USBSTACK_START 994
DEBUG 625 1 ADVICE: USBPD_DPM_Notification:104 995
EVENT 625 1 EVENT_ATTACHED 996
DEBUG 625 1 ADVICE: update USBPD_DPM_UserCableDetection 997
DEBUG 625 1 ADVICE: update USBPD_DPM_SetDataInfo:2 998
DEBUG 626 1 ADVICE: update USBPD_DPM_SetDataInfo:6 999
PE 626 1 PE_SNK_STARTUP 1000
PE 626 1 PE_SNK_WAIT_FOR_CAPABILITIES 1001
IN 719 1 SOP PD3 s:030 H:0x71A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21A4C1
Option: EPW DRP
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
1002
OUT 719 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 1003
DEBUG 719 1 Received: 28 bytes 1004
DEBUG 719 1 PDO[1] = 5000 mV, 3000 mA, 15 W 1005
DEBUG 720 1 PDO[2] = 9000 mV, 3000 mA, 27 W 1006
DEBUG 720 1 PDO[3] = 12000 mV, 3000 mA, 36 W 1007
DEBUG 720 1 PDO[4] = 15000 mV, 3000 mA, 45 W 1008
DEBUG 720 1 PDO[5] = 20000 mV, 5000 mA, 100 W 1009
DEBUG 720 1 APDO [6] - max voltage: 11000 mV 1010
DEBUG 720 1 APDO [7] - max voltage: 21000 mV 1011
PE 720 1 PE_SNK_EVALUATE_CAPABILITY 1012
DEBUG 722 1 Evaluate capabilities... 1013
DEBUG 722 1 PDO mode 1014
PE 722 1 PE_SNK_SEND_REQUEST 1015
ObjectPosition:5
GiveBack:0
NoUSBSuspend:1
OperatingCurrent:5000mA 1016
IN 723 1 SOP s:002 H:0x0161 (id:0, DR:DFP, PR:SRC) GOODCRC 1017
PE 723 1 PE_SNK_SELECT_CAPABILITY 1018
IN 725 1 SOP PD3 ACCEPT s:002 H:0x03A3 (id:1, DR:DFP, PR:SRC) 1019
OUT 725 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 1020
NOTIF 726 1 POWER_STATE_CHANGE 1021
DEBUG 726 1 ADVICE: USBPD_DPM_Notification:90 1022
NOTIF 726 1 REQUEST_ACCEPTED 1023
DEBUG 726 1 ADVICE: USBPD_DPM_Notification:1 1024
PE 726 1 PE_SNK_TRANSITION_SNK 1025
IN 1020 1 SOP PD3 PS_RDY s:002 H:0x05A6 (id:2, DR:DFP, PR:SRC) 1026
OUT 1020 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 1027
NOTIF 1021 1 POWER_STATE_CHANGE 1028
DEBUG 1021 1 ADVICE: USBPD_DPM_Notification:90 1029
NOTIF 1021 1 POWER_EXPLICIT_CONTRACT 1030
DEBUG 1021 1 USB voltage: 20116 mV 1031
PE 1021 1 PE_STATE_READY 1032
NOTIF 1021 1 STATE_SNK_READY 1033
DEBUG 1021 1 ADVICE: USBPD_DPM_Notification:32 1034
PE 1021 1 PE_STATE_SEND_EPRMODE 1035
DEBUG 1021 1 ADVICE: update USBPD_DPM_GetDataInfo:30 1036
OUT 1021 1 SOP s:006 PD3 H:0x128A (id:1, DR:UFP, PR:SNK) EPR_MODE
EPR_MODE : 01000000
Action: 01
Data: 00
1037
IN 1023 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 1038
PE 1023 1 PE_STATE_WAIT_EPRMODE_ACK 1039
IN 1024 1 SOP s:006 PD3 H:0x17AA (id:3, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 02000000
Action: 02
Data: 00
1040
OUT 1024 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 1041
DEBUG 1024 1 ADVICE: update USBPD_DPM_SetDataInfo:23 1042
NOTIF 1024 1 NOTIFY_EPRMODE_ACK 1043
DEBUG 1025 1 ADVICE: USBPD_DPM_Notification:113 1044
IN 1040 1 SOP s:006 PD3 H:0x11AA (id:0, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 03000000
Action: 03
Data: 00
1045
OUT 1040 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 1046
PE 1040 1 PE_STATE_WAIT_EPRMODE_STATUS 1047
DEBUG 1040 1 ADVICE: update USBPD_DPM_SetDataInfo:23 1048
NOTIF 1041 1 NOTIFY_EPRMODE_SUCCEEDED 1049
DEBUG 1041 1 ADVICE: USBPD_DPM_Notification:114 1050
PE 1041 1 PE_SNK_WAIT_FOR_CAPABILITIES 1051
IN 1042 1 SOP s:030 PD3 H:0xF3B1 (id:1, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu0Ch1CReq0DSiz32 [ CHUNK BEGIN ] DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21 1052
OUT 1042 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 1053
OUT 1044 1 SOP s:006 PD3 H:0x9491 (id:2, DR:UFP, PR:SNK) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq1DSiz0 DATA: 0000 1054
IN 1045 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 1055
IN 1047 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ]
EPR SOURCE CAPA
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
DATA: A4C1F4C188008C9630D2 1056
OUT 1047 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 1057
DEBUG 1047 1 Received: 28 bytes 1058
DEBUG 1047 1 PDO[1] = 5000 mV, 3000 mA, 15 W 1059
DEBUG 1048 1 PDO[2] = 9000 mV, 3000 mA, 27 W 1060
DEBUG 1048 1 PDO[3] = 12000 mV, 3000 mA, 36 W 1061
DEBUG 1048 1 PDO[4] = 15000 mV, 3000 mA, 45 W 1062
DEBUG 1048 1 PDO[5] = 20000 mV, 5000 mA, 100 W 1063
DEBUG 1048 1 APDO [6] - max voltage: 11000 mV 1064
DEBUG 1048 1 APDO [7] - max voltage: 21000 mV 1065
DEBUG 1048 1 EPR - received: 4 bytes, 1 PDOs 1066
DEBUG 1048 1 x: 1 - EPR: 0xD230968C 1067
DEBUG 1049 1 0xD230968C 1068
DEBUG 1049 1 EPR AVS - max voltage: 28000 mV 1069
PE 1049 1 PE_SNK_EVALUATE_CAPABILITY 1070
DEBUG 1050 1 Evaluate capabilities... 1071
DEBUG 1050 1 AVS mode 1072
DEBUG 1050 1 RDO after evaluation = 0x91478064 1073
DEBUG 1050 1 static_RDO.d32: 0x91478064 1074
DEBUG 1050 1 Position: 9 1075
DEBUG 1050 1 Voltage: 960 1076
PE 1050 1 PE_SNK_SEND_REQUEST 1077
DEBUG 1050 1 Direct sent of AVSPDO 1078
OUT 1050 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: 6480479100000000
ObjectPosition:1
GiveBack:0
NoUSBSuspend:1
OperatingCurrent:4800mA 1079
IN 1052 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 1080
PE 1052 1 PE_SNK_SELECT_CAPABILITY 1081
IN 1054 1 HRST 1082
NOTIF 1054 1 HARDRESET_RX 1083
DEBUG 1054 1 ADVICE: USBPD_DPM_Notification:30 1084
PE 1054 1 PE_HARD_RESET_RECEIVED 1085
DEBUG 1054 1 ADVICE: update USBPD_DPM_HardReset 1086
DEBUG 1054 1 ADVICE: update USBPD_DPM_HardReset 1087
PE 1054 1 PE_SNK_HARD_RESET_WAIT_VSAFE_0V 1088
GUI 0 BOARD RESET BY USER 1089
DEBUG 505 1 ADVICE: Update BSP_USBPD_PWR_VBUSInit 1090
CAD 505 1 USBPD_CAD_STATE_ATTACHED_WAIT 1091
What is wrong? Why I can’t set properly values of EPR AVS (24V and 5A).
Best regards
Jaroslaw
Jul 23, 2026 09:29 UTC
Another test: I have manually created a bitfield:
uint32_t RDO=0;
RDO|=(100U<<0);
RDO|=(0U<<7);
RDO|=(0U<<8);
RDO|=(960U<<9);
RDO|=(0U<<21);
RDO|=(1U<<22);
RDO|=(0U<<23);
RDO|=(1U<<24);
RDO|=(0U<<25);
RDO|=(0U<<26);
RDO|=(0U<<27);
RDO|=(9U<<28);
DPM_USER_DEBUG_TRACE(PortNum, "RDO after evaluation: 0x%08lX", RDO);
*PtrRequestData=RDO;
USBPD_StatusTypeDef status=USBPD_PE_Send_Request(PortNum, RDO, USBPD_CORE_PDO_TYPE_AVSPDO);
And I have (from trace):
1531 DEBUG 1051 1 RDO after evaluation: 0x91478064
1532 PE 1051 1 PE_SNK_SEND_REQUEST
1533 DEBUG 1051 1 Direct sent of AVSPDO
1534 OUT 1051 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: 6480479100000000 / ObjectPosition:1 / GiveBack:0 / CapabilityMismatch:0 / USBCommunicationCapable:0 / NoUSBSuspend:1 / UnchunkedExtendedMessagesSupported:0 / MaximumOperatingCurrent:1000mA / OperatingCurrent:4800mA
Why?
Best regards
Jaroslaw
Jul 23, 2026 10:41 UTC
And other test…
In EvaluateCapabilities:
else //jeśli If_EPR == 1
//USBPD_SNKRDO_TypeDef rdo;
//rdo.d32=0;
uint32_t RDO=0;
RDO|=(100U<<0);
RDO|=(0U<<7);
RDO|=(0U<<8);
RDO|=(960U<<9);
RDO|=(0U<<21);
RDO|=(1U<<22);
RDO|=(0U<<23);
RDO|=(1U<<24);
RDO|=(0U<<25);
RDO|=(0U<<26);
RDO|=(0U<<27);
RDO|=(9U<<28);
uint32_t RDO=0;
//RDO=(RDO&~0x0000007FU)|(100U<<0);
//RDO=(RDO&~0x0007FE00U)|(960U<<9);
//RDO=(RDO&~0x00400000U)|(1U<<22);
//RDO=(RDO&~0x01000000U)|(1U<<24);
//RDO=(RDO&~0xF0000000U)|(9U<<28);
RDO=0x92478064UL;
//DPM_USER_DEBUG_TRACE(PortNum, "static_RDO.d32: 0x%08lX", static_RDO.d32);
//*PtrRequestData=rdo.d32;
//USBPD_StatusTypeDef status=USBPD_PE_Send_Request(PortNum, rdo.d32, USBPD_CORE_PDO_TYPE_AVSPDO);
//USBPD_StatusTypeDef status=USBPD_PE_Send_Request(PortNum, RDO, USBPD_CORE_PDO_TYPE_AVSPDO);
//if(status!=USBPD_OK)
// DPM_USER_DEBUG_TRACE(PortNum, "USBPD_PE_Send_Request failed");
And in GetDataInfo:
*Size=8;
uint8_t *data=(uint8_t*)Ptr;
uint32_t first_part=0x92478064UL;
data[0]=(first_part & 0xFF);
data[1]=((first_part>>8) & 0xFF);
data[2]=((first_part>>16) & 0xFF);
data[3]=((first_part>>24) & 0xFF);
uint32_t second_part=960U;
data[4]=(second_part & 0xFF);
data[5]=((second_part>>8) & 0xFF);
data[6]=((second_part>>16) & 0xFF);
data[7]=((second_part>>24) & 0xFF);
DPM_USER_DEBUG_TRACE(PortNum, "Direct sent of AVSPDO: %02X%02X%02X%02X %02X%02X%02X%02X",data[3],data[2],data[1],data[0],data[7],data[6],data[5],data[4]);
break;
And I have:
1831 DEBUG 1052 1 Direct sent of AVSPDO: 92478064 000003C0
1832 OUT 1052 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: 6480479264804792 / ObjectPosition:1 / GiveBack:0 / CapabilityMismatch:0 / USBCommunicationCapable:1 / NoUSBSuspend:0 / UnchunkedExtendedMessagesSupported:0 / MaximumOperatingCurrent:1000mA / OperatingCurrent:4800mA
EPR data from source:
1811 IN 1049 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ] / EPR SOURCE CAPA / [1] Fixed : 5V - 3A / [2] Fixed : 9V - 3A / [3] Fixed : 12V - 3A / [4] Fixed : 15V - 3A / [5] Fixed : 20V - 5A / [6] EPR : [11V - 3.3V] - 60W / [7] EPR : [21V - 3.3V] - 60W / [8] Fixed : 28V - 5A / [9] EPR : [28V - 15V] - 140W / DATA: A4C1F4C188008C9630D2
I have verision 5.4.0 of firmware.
Best regards
Jaroslaw
Jaroslaw_TAuthorBest answer
Hello
uint32_t EPR=0;
uint8_t src_power;
break;
rdo.d32=0;
and trace:
Option: EPW DRP
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
19732
ObjectPosition:5
GiveBack:0
NoUSBSuspend:1
EPR_MODE : 01000000
Action: 01
Data: 00
19767
EPR_MODE : 02000000
Action: 02
Data: 00
19770
EPR_MODE : 03000000
Action: 03
Data: 00
19775
EPR SOURCE CAPA
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
ObjectPosition:1
GiveBack:0
NoUSBSuspend:0
Thank You all
Best regards
Jaroslaw
