Enter UART bootloader at STM32H743XIH6 (Rev. X) fails
has anyone succeed with this task?
I run the UART also as CLI interface on PA9 and PA10. Documentations says, there is the UART bootloader on this pins. If I rise the boot0 pin at power up my application doesn't start. So I try use STM32CubeProgrammer and also terminal program to send 0x7F. (I checked all data on the line with a scope).
I got no answer. What could happen here? Is there special handling required because of the secure bootloader options?
I had never problems with STM32 bootloaders until now...
Sebastian Förster
