Lars Beiderbecke
Senior III
Apr 23, 2020 2:09 PM UTC
Does USB library work under heavy interrupt load?
I'm implementing a USB Host (HID Class) on a STM32F7 in order to connect a mouse.
The problem is that in about 50% of cases, phost->gState ends up in HOST_ABORT_STATE, where exactly I do not know. If this does not happen, my user function USBH_HID_EventCallback() is never called more than once.
What is special about my setting is that I have external interrupts enabled, which trigger about every half microsecond when under load. The STM32 keeps up with that, but I wonder if those interrupts might interfere with the USB library, especially the low-level parts dealing with signals.
Does anybody have any insights on how the USB library deals with interrupts? Will it disable interrupts for critical sections? Is there a recommendation how often USBH_Process() should be called?
Lars Beiderbecke
Senior III
Apr 23, 2020 2:42 PM UTC
I've just tested with external interrupts disabled, but I still get HOST_ABORT_STATE. So at least in this case, interrupts are not the cause.
I guess I'll withdraw my question. :smiling_face_with_smiling_eyes:
Apr 23, 2020 3:01 PM UTC
Interrupts at 2MHz are likely to cause all sorts of problems, if the chip can even keep up.
Lars Beiderbecke
Senior III
Apr 23, 2020 3:04 PM UTC
No, that's working perfectly fine at 200 MHz system clock. The system is about 40% idle at max IR load.
