Dat Tran
Senior II
Sep 13, 2022 1:27 PM UTC
Does STM32H7 (STM32H743) support usb gadget ethernet?
Anyone know  STM32H7 (STM32H743) support usb gadget ethernet?
I read somewhere STM32F7 does, but not sure about STM32H7
Many thanks.
FBLBest answer
Sep 14, 2022 4:59 PM UTC
Hello @Community member​
In ux_host_class_cdc_ecm.h file under
STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AZRTOS H7\2.1.0\Middlewares\ST\usbx\common\usbx_host_classes\inc
we can find ethernet is supported as an USB host
#define UX_HOST_CLASS_CDC_ECM_ETHERNET_IP           0x0800
#define UX_HOST_CLASS_CDC_ECM_ETHERNET_ARP           0x0806
#define UX_HOST_CLASS_CDC_ECM_ETHERNET_RARP          0x8035
#define UX_HOST_CLASS_CDC_ECM_ETHERNET_PACKET_SIZE       1536
Also, in STM32Cube\Repository\STM32Cube_FW_H7_V1.10.0\Middlewares\ST\STM32_USB_Host_Library\Class\CDC\Inc Ethernet is among supported classes
FBLBest answer
Dat Tran
Dat TranAuthor
Senior II
Sep 19, 2022 12:08 AM UTC
very nice, thank you so much.
mohamed.ayed
Oct 15, 2022 11:10 AM UTC
Hi Dat Tran,
ST USB Host lib does not support CDC-ECM / RNDIS Class so as mentioned by @F.Belaid​  you can use USBX (Azure RTOS Middleware) it support CDC-ECM Host Class.
https://learn.microsoft.com/en-us/azure/rtos/usbx/usbx-host-stack-6
Note actually we don't have a Host CDC ECM sample application.
