kjais
Does STM32F746ZG, supports low level drivers for UART???
  • December 14, 2018
  • 8 replies
  • 1770 views
If I am making UART6, as HAL layer, it's working fine but if it configure it as LL api, it's giving garbage values.
After Forever
Senior III
December 14, 2018
Yes STM32CubeF7 does include LL drivers, and UART/USART is supported.
You must be doing something wrong. Show your code.
kjais
kjaisAuthor
I am sharing my code in the Attachment.
please check and let me know, what I am doing wrong.
Basically I am configuring 2 UART
UART2 and UART6
UART6 on HAL layer
UART2 on LL
it giving me a garbage value on UART6
but if I make both on HAL layer, it's giving me correct value on the comport
December 14, 2018
Review the peripheral register settings in the working and non-working cases, compare and contrast.
kjais
kjaisAuthor
thanks for your reply.
Kindly let me know, how can I check the peripheral register settings?
December 23, 2018
Use the debugger? Open a "Peripheral View" or equivalent option, dump the memory region?
waclawek.jan
Read out the registers' content and compare.
Also make sure the related APB clocks are set as you expect them to be.
