callsignhermit
May 17, 2026 06:56 UTC
Documentation of the STM32Cube source code style ?
Looking through the STM32Cube codebase, I’ve noticed a fairly strange but thoroughly consistent coding style. Indentation size is 2 spaces, using space for indentation; bracing style is more similar to Allman’s style rather than K&R and 1TBS. Naming style is also uniform, using CamelCase for external identifiers such as functions, structure fields, and global variables; along with a bit of Hungarian notation here and there (for example, pTxBuffPtr).
This style is mechanically consistent through STM32Cube firmwares, drivers (LL, HAL, and CMSIS), code generated by STM32CubeMX, and BSP drivers. Even example projects follow suit.
Could STM employees please share with us some documentation or guideline regarding this coding style? Looking for something similar to the Linux Kernel Coding Style and the Google C++ Style Guide. Configurations for formatter tools such as clang-format would also be appreciated.
May 18, 2026 10:00 UTC
Hello @callsignhermit
Unfortunately, there is no document illustrating the HAL coding style. But you can configure your own code style using the feature code style in Cube IDE .
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
callsignhermit
May 20, 2026 09:04 UTC
Can we request ST to release such document? Assuming something like it already exists among the development team who maintain the codebase, of course.
waclawek.jan
May 20, 2026 09:59 UTC
Are you planning to contribute to Cube/HAL?
Andrew Neil
May 18, 2026 10:05 UTC
@callsignhermit wrote:
I’ve noticed a fairly strange ... coding style.
In what way "strange" ?
callsignhermit
May 18, 2026 11:05 UTC
I apologize if I came off rude. The style looked strange to me because the K&R layout, snake case and the refrain from Hungarian style has dominated the C projects I have worked on.
Andrew Neil
May 18, 2026 11:20 UTC
No worries about rudeness.
It is a truth universally acknowledged that, in any group of N programmers, there will be at least N+1 different views on what constitutes "good style"...
