T J
Senior III
August 28, 2018
DMA buffer position
  • August 28, 2018
  • 1 reply
  • 1672 views
In the M0 I used this code to get the current pointer position
 U1RxBufferPtrIN = U1RxBufSize - huart2.hdmarx->Instance->CNDTR;
but on the H7 this register is not available.
How can I find the current Rx pointer position from the Uart DMA controller ?
T J
T JAuthor
Senior III
August 28, 2018
U1RxBufferPtrIN = U1RxBufSize - __HAL_DMA_GET_COUNTER(huart7.hdmarx);
this works !
but how to work the syntax of direct access ?
this does not compile ??
U1RxBufferPtrIN = U1RxBufSize - huart7.hdmarx->Instance.NDTR;
