emil28
DFU Cube F4 doesn't work
I would like to try the DFU on my Nucleo F413ZH. I have downloaded Cube F4 1.25.0, and opened the application "DFU_Standalone" in the "USB_Device" folder. I have also installed "DfuSe Demonstrator" and the drivers. In the peripheral manager, I can see the "STM32 Bootloader":
Unfortunately, the "DfuSe Demonstrator 3.0.6" doesn't detect the device:
I am working on Windows 10 64 bits and IAR 8.42.2.
Any idea on what I am missing ?
Thanks.
Amel NASRI
Hi @emil28​ ,
Is same problem faced if you use STM32CubeProgrammer instead of DfuSe Demonstrator?
This later is no more maintained to support new STM32 devices.
-Amel
emil28
emil28Author
Thanks for your quick answer.
No, STM32CubeProgrammer is able to detect the DFU device:
0693W000004JSTtQAO.jpgBut unfortunately, when I try to updload a new hex file to the uC, nothing happens, CubeProgrammer is blocked at this step:
0693W000004JSY0QAO.jpgAny idea ?
emil28
emil28Author
I still have my problem. Cube MX Programmer is blocked when I try to download the hex file to the uC.
Any idea ? You can find attached the DFU_Configuration ioc file.
