eduardo2
Description of STM32F2xx HAL drivers
  • August 11, 2014
  • 4 replies
  • 952 views
Posted on August 11, 2014 at 18:28
Is there any description of HAL library for STM32F2s.
I found the UM1725 documentation but only applies for STM32F4s.
Anything similar for STM32F2s???
Thanks,
#stm32f2 #hal-library
August 11, 2014
Posted on August 11, 2014 at 18:46
Wouldn't they be materially identical? The key differences would be the M3/M4 core, memory (size, ccm, etc) and the clock/pll, and regulator.
eduardo2
eduardo2Author
Posted on August 11, 2014 at 20:14
I don't know. There is a specific documentation UM1061 STM32F2xx for Standard Peripheral Library for STM32F2s, and I thought that there may be one HAL library for this chip also. but may be not.
Montassar BEN ROMDHANE_O
August 26, 2014
Posted on August 26, 2014 at 16:33
Hi ed@mtrx,
You can use the UM1725 document describing the STM32CubeF4 HAL drivers, since these two devices share a lot of similarities.
The STM32CubeF2 HAL drivers description document is under finalization and will be online as soon as possible.
Thank you for your interest in our STM32Cube solution.
With regards.
Stefan Meyre
Posted on February 19, 2015 at 11:16
Hi Mister White, I guess you are working on the description of the STM32F3 HAL Drivers as well? I could not find them in the ST documentation database... Kind regards Stefan
