madhavi U
Jul 26, 2023 7:04 AM UTC
declaring variables with ram address
I declared some test variable like,
unsigned short *testvar= (unsigned short *)0x20020074;
unsigned char *testvar1[4] = {(unsigned char *)0x20020076,(unsigned char *)0x20020077,
                                                  (unsigned char *)0x20020078,(unsigned char*)0x20020079};
but unfortunately in mid I left some part of the ram space and again declared a variable like,
unsigned short *testvar2= (unsigned short *)0x20020092;
I'm computing checksum from 0x20020074 to 0x20020092 and storing into flash , but  0x20020080 to 0x20020091 nowhere i'm declaring this space .is it create problem when i'm retrieving data from flash into ram?
Jul 26, 2023 3:44 PM UTC
Hello @madhavi U ,
Do you mean retrieving data from RAM to Flash?  you may need to check this post Solved: Declaring variables in SRAM1-3 areas of H7 devices... - STMicroelectronics Community
Hope this helps!
