vchau.1
Jan 6, 2023 12:55 PM UTC
Custom Bootloader design for STM32F4
Hi All,
Kindly let me know how to customize standard ST bootloader and change the default UART pins, Currently bootloader working on UART1 and UART3, but i want bootloader on UART2
Microcontroller Details -STM32F4
MM..1
MM..1Best answer
Jan 6, 2023 5:29 PM UTC
Microcontroller Details -STM32F4 is as all stars in one galaxy. Read AN2606
KnarfB
Jan 6, 2023 1:19 PM UTC
The in-chip bootloader is in ROM and cannot be changed. You may look into https://github.com/STMicroelectronics/stm32-mw-openbl for a SW based solution.
hth
KnarfB
Jan 6, 2023 1:24 PM UTC
You can code your own software to do whatever you want
The front flash sectors are 16KB to accommodate you creating you own loader/startup methods.
MM..1
MM..1Best answer
