Configure External Interrupt and Alternate function on same pin using Cube-MX
I'm testing a code using Nucleo-L476RG and an analog to digital converter. This ADC uses SPI communication and shares its RDY (end of conversion) and DOUT functions on the same pin, that is, after reading the converted data on the pin, it become RDY pin and can drive a external interrupt on microcontroller.
My question is: how can I enable the External Interrupt event on a pin already configurated as MISO of SPI using Cube-MX and HAL?
