Barbie
COM port disconnect from USB way to know it STM32F205
Posted on November 17, 2014 at 07:29
I use today the USB OTG with ST example stm32_vcp_1.3.1.
I want to know if there a way to know that a connection I made with teh PC by openning COM port close.
I use today the function
DCD_OTG_ISR(USB_OTG_CORE_HANDLE *pdev)
 but it only tell me whne a phisical connection was remove.
Bar.
#stm32f205-usb-otg-stm32_vcp_1.3.
chen
Posted on November 17, 2014 at 11:44
Hi
I do not think there is any way to tell on a USB CDC device if the host VirtualCOM port has been closed.
''I use today the function
 but it only tell me whne a phisical connection was remove.''
Yes, that is correct. The USB device can tell if it has been unplugged.
A way you will be able to tell is to implement a message protocol that includes a 'ping' and detect if the 'ping' stops.
AME MCU Support Center BB
Posted on January 29, 2015 at 17:14
Hi Strauss,
If I have well understood your query, you need to know when user opens/closes the com port? If so, this is possible from USB point of view but host terminal dependent.
Which terminal are you using ?
Note that with some terminal, it may be impossible to report com port open/close events.
With regards,
