Code stucks at MX_USB_DEVICE_Init();
Hello, I use STM32F103C8Tx but USB communication does not work as it intends to. Sometimes codestuck at MX_USB_DEVICE_Init(); function.. More spesifically it gets stuck at
USBx->BTABLE = BTABLE_ADDRESS;
line inside of MX_USB_DEVICE_Init();
When I connect other side of the USB Communication, it gets fixed.
What might be the reason behind that? So do I need to connect USB device, or will it stuck in MX_USB_DEVICE_Init(); function?
Note: It is not related to interrupt priority.
