Changing GPDMA Interrupts
I would like to enable and disable certain interrupts pertaining to the GPDMAs within my program at times. Particularly the transfer complete interrupt. I would assume that I should be able to simply change the register value with GPDMA2->C0CR &=~GPDMA_C0CR_TCIE; but it appears that im only allowed to reference the SECCGFR, PRIVCFGR, RCFGLOCKR, MISR, and SMISR registers. Why is this the case? What must I do to be able to disable the TCIE interrupt?
I have tried to use __HAL_DMA_DISABLE_IT(&hdma_adc2, DMA_IT_TC); which throws a hard fault.
Thank you!
tw1Best answer
I have solved it using the LL functions. Thank you.
Hello @tw1
Could you please specify the MCU you are using?
Also, could you share your code so that we can assist you more effectively?
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
tw1AuthorBest answer
