DextroLaev
Jul 20, 2021 6:30 AM UTC
Can't we use HAL_Delay() inside an Interrupt Service Routine ?
I am new to stm32, I have a stm32F407VG discovery board. I tried to implement an interrupt using the user button and added HAL_Delay() inside the interrupt function. After I press the Button the Interrupt execute but it got stuck there, it is not coming back to main(). What should I do to handle this ?
Tesla DeLoreanBest answer
Jul 20, 2021 1:07 PM UTC
Problematic in ISR and call-backs that HAL makes from same interrupt context.
Figure out a better way of coming back later to follow up.
Or change the SysTick to have the highest priority, at its own preemption level, keeping it very short.
Jul 20, 2021 1:02 PM UTC
Yes, but it's not best practice.
You need to ensure the SysTick interrupt still fires, so SysTick must be at a higher preemption priority (numerically lower) than the interrupt you're currently in.
DextroLaev
Jul 21, 2021 5:02 AM UTC
Problem solved by reducing the interrupt priority.
