Senior
December 10, 2025
Can't find the Definition inside stm32-mw-usbpd-core
  • December 10, 2025
  • 3 replies
  • 367 views
In your middle-ware for the usbpd i can't find any of the definition for the functions in usbpd_core.h.
https://github.com/STMicroelectronics/stm32-mw-usbpd-core
Example
USBPD_PE_SVDM_RequestMode
* USBPD_PE_SVDM_RequestModeEnter
USBPD_PE_SVDM_RequestModeExit
Can't be found anywhere in the repo.  It looks like you compiled them all down to assembly files.  Is there a reason for this or am i missing something?
Best answer by FBL
Hi @Brenden_PLUS
Not sure why do you need the source for the library. This is integrated in lib .a and the source files cannot be shared. For that reason the user manual attached explain the main reason behind the functions in source files.
I hope it's clear.
Hi @Brenden_PLUS
You can find the related documentation required in precompiled html user manual here.
Senior
December 10, 2025
That's fine i was looking for the source to usbpd_core.h.
Trying to figure out how the system works and there doesn't seem to be a usbpd_core.c or any place were the functions that live in usbpd_core.h are actually defined.
FBLBest answer
Hi @Brenden_PLUS
I hope it's clear.
