Zhou JianQiang
Senior
Can stm32f1 use stm32f4 STM32_USB_Device_Library directly?
Hi :
I want to use MTP & HID simultaneously in stm32f103RE, but there is not  CompositeBuilder and MTP in stm32f1 STM32_USB_Device_Library, so can I use stm32f4 STM32_USB_Device_Library directly?
Or is there any other solution to use MTP & HID simultaneously in stm32f103RE?
Hi @Zhou JianQiang
You can use composite builder class from different product, however as you may know, it may be not fully supported due to limited bandwidth.
