Apr 15, 2024 5:12 AM UTC
Can i OTA upgrade my MCU(STM32h745ziq) using cyw43439 chips?
During the project, I need to create equipment that can be updated wirelessly using WiFi. So far, the MCU has been implemented to connect to the router. Is it possible to implement the ota upgrade with the cyw43439chip?
Andrew Neil
Andrew NeilBest answer
Apr 15, 2024 9:51 AM UTC
The cyw43439 is just a means to transport the data - sure, you could use that to transport the data which forms your firmware update.
Andrew Neil
