VCasa.3
Feb 8, 2023 12:24 PM UTC
Calling osDelay from a function called inside a Task
I have a doubdt and I haven't found the solution on the internet (probably I haven't asked properly or I have been missunderstood)
The thing is that I have a peripheral driver,with a function to write and read to and from SPI, and between them, I have a delay.
If I have a Task, and from this task I call that function, with the delay being osDelay(), will it work, as the normal behabiour of calling osDelay from the task itself (allowing other tasks to run during the delay).
Thank you so much!
KnarfB
KnarfBBest answer
Feb 8, 2023 12:59 PM UTC
osDelay() is the correct funtion for OS-aware delay.
https://www.keil.com/pack/doc/CMSIS/RTOS2/html/group__CMSIS__RTOS__Wait.html
Doesn't matter if its called directly in the task loop or indirectly from a function in a task loop.
hth
KnarfB
KnarfB
KnarfBBest answer
hth
KnarfB
VCasa.3
VCasa.3Author
Feb 8, 2023 1:07 PM UTC
Perfect, thank you!
