MaxR
Aug 21, 2018 8:03 AM UTC
Bug in STM32H7 1.3.0 USB generated code
I am using a STM32H7 USB in MSC mode. When I generate the source code with STM32CUBEMX 4.26.1 and STM32CubeH7 Firmware Package V1.3.0 / 04-July-2018, i noticed that inside USBD_HS_USR_BOSDescriptor() in usbd_desc.c, USBD_HS_BOSDesc definition can not be found. Looks like USBD_HS_BOSDesc is not defined anywhere in code
Khouloud GARSI
Khouloud GARSIBest answer
Sep 26, 2018 5:01 PM UTC
Hi @MaxR​ ,
I recommend to use STM32CUBEMX 4.27.0 : The "USBD_HS_USR_BOSDescriptor" is correctly defined inside the "usbd_desc.c".
Could you please check from your side.
Khouloud.
Khouloud GARSI
Hi @MaxR​ ,
Khouloud.
MaxR
MaxRAuthor
Sep 29, 2018 7:09 AM UTC
Hi @Khouloud GARSI​
Thanks, I confirm. It works on 4.27
Kind regards,
Max
