Buffer size for USB on the STM32L4 device.
Hi
I am using the stm32L433 device and want to use the USB port for communication. I am planning to use it as a CDC class, and to start of with using the cube (then modify it to use registers only). I have read some place that it requires a large buffer when using it, is this correct? I am assuming there will be some overhead for the driver, and then for my application. But I am not sure what this should be set to. Anyone any idea?
Many Thanks
Scott
