VSoun.1
Aug 10, 2022 6:44 AM UTC
Booting from flash memory not working in stm32G0b1ke mcu
We are flashing the firmware to stm32g0b1ke mcu using i2c in-application programming.after flashing the firmware to mcu,changed the boot configuration to boot from flash memory.I set the boot pin to 0 and option bytes to 0xFAFFFEAA for booting from flash memory.
Setting the boot pin 0 not taking the firmware from flash memory.At this mode i cant access the mcu.changing the boot pin to 1 loading the system memory program.
whats the reason booting from flash memory not working?
ChahinezC
Sep 23, 2022 8:56 AM UTC
Hello @VSoun.1​,
I advise you checking the STM32 boot process FAQ. It might help you.
Thank you.
Chahinez
