udilevy
April 19, 2016
Boot1 pin left floating
  • April 19, 2016
  • 989 views
Posted on April 19, 2016 at 14:38
I am now working on a design with stm32l, the BOOT1 pin was left floating in this design, Is that a valid configuration? Does BOOT1 have a built in pull down/up resistor, or is it an unstable configuration?
#stm32 #bootloader
April 19, 2016
Posted on April 19, 2016 at 14:54
BOOT0 would be more concerning, that would want a pull-down.
The general rule is to enforce the behaviour you want externally. The Data Manual should indicate the pin behaviour.
Nesrine M_O
Posted on April 19, 2016 at 15:17
Hi levy.udi.001,
I recommend you to have a look to the Getting started hardware application note related to your STM32 product, it gives a hardware implementation overview of the development board features (Boot configuration, Power supplies...)
For example
http://www2.st.com/content/ccc/resource/technical/document/application_note/fd/f4/6b/40/9a/b5/41/a2/DM00112257.pdf/files/DM00112257.pdf/jcr:content/translations/en.DM00112257.pdf
Application note (Getting started with STM32L0xx hardware development)
-Syrine-
