Oct 18, 2024 11:55 AM UTC
Bad Range using RFM95 and STM32L476RG
How can I achieve optimal range for LoRa node-to-node communication? I'm using the RFM95 module at a frequency of 932 MHz but experiencing very poor range—data transmission cuts out at only 4 feet. I have a compatible antenna, which is properly soldered as well.
STTwo-32
STTwo-32Best answer
Oct 18, 2024 12:10 PM UTC
I don't think so. And even if it is, is not something that ST delivered. So, you need to check with the person who worked on this FW.
Best Regards.
STTwo-32
STTwo-32
Oct 18, 2024 12:02 PM UTC
Hello @Zeeshan123
This depend on the module you are using for LoRa communication (the RFM95 module). So, it will be a good idea to check with the manufacturer of this module. The 4 feet to me seems to be very strange for me.
Best Regards.
STTwo-32
Oct 18, 2024 12:08 PM UTC
Yes, its strange for me as well. I dont what might be the issue probably the module is the bad or the firmware needs revisions
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
