NGovi.1
Feb 22, 2023 4:47 AM UTC
B-L475E-IOT01A1 loaded with reference code X-CUBE-GCP Iot version 1.0.0 is getting stuck at "Setting the RTC from the network time" USE_CLEAR_TIMEDATE is defined
When checked on telnet that there was no response from the ST web page, when requested for header
Is there any issue in using ST website for getting the real time?
grd
Feb 23, 2023 3:29 PM UTC
http://www.st.com still responds to Firefox browser GET requests. It does not with wget or curl.
It's worth mimicking the header fields of a working GET request in the embedded application.
Or just point to an HTTP server which is less picky.
NGovi.1
NGovi.1Author
Feb 24, 2023 3:43 AM UTC
Thanks for the quick reply. Are you suggesting to use a different url other than http://www.st.com?
