GreenGuy
GreenGuyBest answer
Senior III
May 30, 2023 10:04 PM UTC
Yes, this is what prompted my look at if CubeMx supports the feature selection. Sadly, ST has not worked on this. However there is an example in git called B-U585I-IOT02A_MODULE_MANAGER_THREADX.
The MOOC only makes mention of ModuleX but does not go into any detail.
GreenGuy
GreenGuyAuthor
Senior III
May 25, 2023 10:17 PM UTC
The first thing I notice is that the Software Packs>Select Components in CubeMX does not include Modules in the ThreadX section. However, the needed txm_module.h is present in ...\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AZRTOS-H7\3.1.0\Middlewares\ST\threadx\common_modules along with the other files needed.
I guess CubeMX does not currently support adding Module support to the project.
May 30, 2023 8:17 AM UTC
Hello @Community member​,
Check this wiki about ThreadX
Introduction to THREADX - stm32mcu
I will let my colleague check if CubeMX is supporting middleware.
Ghofrane GSOURI
May 30, 2023 8:42 AM UTC
First let me thank you for posting.
I advise you, to get inspired form the steps described in this workshop: MOOC - Azure RTOS step by step workshop
Thx
Ghofrane
GreenGuy
GreenGuyAuthorBest answer
Senior III
