bjornpaulstrom
ADC with HAL, EOC flag never set
  • October 11, 2016
  • 956 views
Posted on October 11, 2016 at 11:54
Hello I am trying to use the ADC like this:
ADC_ChannelConfTypeDef sConfig;
 adc.Instance = ADC1;
 adc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
 adc.Init.Resolution = ADC_RESOLUTION_12B;
 adc.Init.ScanConvMode = DISABLE;
 adc.Init.ContinuousConvMode = DISABLE;
 adc.Init.DiscontinuousConvMode = DISABLE;
 adc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 adc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 adc.Init.NbrOfConversion = 1;
 adc.Init.DMAContinuousRequests = DISABLE;
 adc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 if (HAL_ADC_Init(&adc) != HAL_OK)
   //Error_Handler();
 sConfig.Channel = ADC_CHANNEL_0;
 sConfig.Rank = 1;
 sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
 if (HAL_ADC_ConfigChannel(&adc, &sConfig) != HAL_OK)
   //Error_Handler();
GPIO_InitTypeDef GPIO_InitStruct;
 if(adcHandle->Instance==ADC1)
   __HAL_RCC_ADC1_CLK_ENABLE();
   GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4;
   GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
   HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
HAL_ADC_Start
g_AdcHandle
for
if
HAL_ADC_PollForConversion
g_AdcHandle
1000000
HAL_OK
g_ADCValue
HAL_ADC_GetValue
g_AdcHandle
g_MeasurementNumber
 But it gets stuck in this code, looking for EOC flag:
while(!(__HAL_ADC_GET_FLAG(hadc, ADC_FLAG_EOC)))
    /* Check if timeout is disabled (set to infinite wait) */
    if(Timeout != HAL_MAX_DELAY)
      if((Timeout == 0U) || ((HAL_GetTick() - tickstart ) > Timeout))
        /* Update ADC state machine to timeout */
        SET_BIT(hadc->State, HAL_ADC_STATE_TIMEOUT);
        /* Process unlocked */
        __HAL_UNLOCK(hadc);
        return HAL_TIMEOUT;
Any ideas why this happens?
#adc #hal
bjornpaulstrom
Posted on October 11, 2016 at 19:00
I managed to solve this, Part of my code was executing in an interrupt and this was blocking the EOC flag from getting set, after I moved it out, it worked great.
Walid FTITI_O
October 11, 2016
Posted on October 11, 2016 at 20:16
Hi paulstrom.bjorn,
Thank you for sharing your finding .
You can manage the interrupt conflict by setting the priorities of each interrupt in the NVIC register to be executed by priority's order and avoid such issue.
-Hannibal-
