Feb 6, 2025 11:30 AM UTC
ADC in DMA circular mode with LL Library Problems
int loopTime = 0, maxLoopTime = 0;
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_ADC2_Init();
  MX_COMP1_Init();
  MX_COMP2_Init();
  MX_COMP4_Init();
  MX_DAC3_Init();
  MX_OPAMP1_Init();
  MX_OPAMP2_Init();
  MX_OPAMP3_Init();
  MX_TIM1_Init();
  MX_IWDG_Init();
  MX_I2C3_Init();
  /* USER CODE BEGIN 2 */
  SystemManager_Start();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
LL_IWDG_ReloadCounter(IWDG);
SystemManager_Task();
static uint64_t _t = 0;
loopTime = HAL_GetTick_us()-_t;
_t = HAL_GetTick_us();
if(HAL_GetTick() > 5000 && loopTime > maxLoopTime)
maxLoopTime = loopTime;
  /* USER CODE END 3 */
  * @retval None
void SystemClock_Config(void)
  LL_FLASH_SetLatency(LL_FLASH_LATENCY_4);
  while(LL_FLASH_GetLatency() != LL_FLASH_LATENCY_4)
  LL_PWR_EnableRange1BoostMode();
  LL_RCC_HSE_Enable();
   /* Wait till HSE is ready */
  while(LL_RCC_HSE_IsReady() != 1)
  LL_RCC_LSI_Enable();
   /* Wait till LSI is ready */
  while(LL_RCC_LSI_IsReady() != 1)
  LL_RCC_HSE_EnableCSS();
  LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_6, 85, LL_RCC_PLLR_DIV_2);
  LL_RCC_PLL_EnableDomain_SYS();
  LL_RCC_PLL_Enable();
   /* Wait till PLL is ready */
  while(LL_RCC_PLL_IsReady() != 1)
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_2);
   /* Wait till System clock is ready */
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  /* Insure 1us transition state at intermediate medium speed clock*/
  for (__IO uint32_t i = (170 >> 1); i !=0; i--);
  /* Set AHB prescaler*/
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
  LL_SetSystemCoreClock(170000000);
   /* Update the time base */
  if (HAL_InitTick (TICK_INT_PRIORITY) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM7 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @PAram  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  /* USER CODE BEGIN Callback 0 */
  /* USER CODE END Callback 0 */
  if (htim->Instance == TIM7) {
    HAL_IncTick();
  /* USER CODE BEGIN Callback 1 */
  /* USER CODE END Callback 1 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  __disable_irq();
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @PAram  file: pointer to the source file name
  * @PAram  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
void MX_ADC1_Init(void)
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  LL_ADC_InitTypeDef ADC_InitStruct = {0};
  LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
  LL_ADC_CommonInitTypeDef ADC_CommonInitStruct = {0};
  LL_ADC_INJ_InitTypeDef ADC_INJ_InitStruct = {0};
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  LL_RCC_SetADCClockSource(LL_RCC_ADC12_CLKSOURCE_SYSCLK);
  /* Peripheral clock enable */
  LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_ADC12);
  LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOA);
  LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOB);
  /**ADC1 GPIO Configuration
  PA0   ------> ADC1_IN1
  PA2   ------> ADC1_IN3
  PB1   ------> ADC1_IN12
  GPIO_InitStruct.Pin = VCC_HV_MON_Pin;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ANALOG;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  LL_GPIO_Init(VCC_HV_MON_GPIO_Port, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = U_CURRENT_Pin;
  LL_GPIO_Init(U_CURRENT_GPIO_Port, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = W_CURRENT_Pin;
  LL_GPIO_Init(W_CURRENT_GPIO_Port, &GPIO_InitStruct);
  /* ADC1 DMA Init */
  /* ADC1 Init */
  LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_1, LL_DMAMUX_REQ_ADC1);
  LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_1, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
  LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PRIORITY_HIGH);
  LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MODE_CIRCULAR);
  LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PERIPH_NOINCREMENT);
  LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MEMORY_INCREMENT);
  LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PDATAALIGN_HALFWORD);
  LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MDATAALIGN_HALFWORD);
  /* ADC1 interrupt Init */
  NVIC_SetPriority(ADC1_2_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_EnableIRQ(ADC1_2_IRQn);
  /* USER CODE BEGIN ADC1_Init 1 */
LL_DMA_ConfigAddresses(DMA1,LL_DMA_CHANNEL_1,LL_ADC_DMA_GetRegAddr(ADC1, LL_ADC_DMA_REG_REGULAR_DATA),
(uint32_t)Veriables_Analog.AdcVal.mcBusVoltage,LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_SetDataLength(DMA1,LL_DMA_CHANNEL_1,3);
  /* Enable DMA transfer interruption: transfer complete */
  LL_DMA_EnableIT_TC(DMA1,LL_DMA_CHANNEL_1);
  /* Enable DMA transfer interruption: half transfer */
//  LL_DMA_EnableIT_HT(DMA1,LL_DMA_CHANNEL_1);
  /* Enable DMA transfer interruption: transfer error */
  LL_DMA_EnableIT_TE(DMA1,LL_DMA_CHANNEL_1);
LL_DMA_EnableChannel(DMA1,LL_DMA_CHANNEL_1);
  /* USER CODE END ADC1_Init 1 */
  /** Common config
  ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_12B;
  ADC_InitStruct.DataAlignment = LL_ADC_DATA_ALIGN_RIGHT;
  ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
  LL_ADC_Init(ADC1, &ADC_InitStruct);
  ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_SOFTWARE;
  ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_ENABLE_3RANKS;
  ADC_REG_InitStruct.SequencerDiscont = LL_ADC_REG_SEQ_DISCONT_DISABLE;
  ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_CONTINUOUS;
  ADC_REG_InitStruct.DMATransfer = LL_ADC_REG_DMA_TRANSFER_UNLIMITED;
  ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_PRESERVED;
  LL_ADC_REG_Init(ADC1, &ADC_REG_InitStruct);
  LL_ADC_SetGainCompensation(ADC1, 0);
  LL_ADC_SetOverSamplingScope(ADC1, LL_ADC_OVS_DISABLE);
  ADC_CommonInitStruct.CommonClock = LL_ADC_CLOCK_SYNC_PCLK_DIV4;
  ADC_CommonInitStruct.Multimode = LL_ADC_MULTI_INDEPENDENT;
  LL_ADC_CommonInit(__LL_ADC_COMMON_INSTANCE(ADC1), &ADC_CommonInitStruct);
LL_ADC_SetCommonClock(ADC12_COMMON,LL_ADC_CLOCK_SYNC_PCLK_DIV4);
while(LL_ADC_GetCommonClock(ADC12_COMMON) != LL_ADC_CLOCK_SYNC_PCLK_DIV4){}
//Errors_Handler();
//  ADC_INJ_InitStruct.TriggerSource = LL_ADC_INJ_TRIG_EXT_TIM1_CH4;
//  ADC_INJ_InitStruct.SequencerLength = LL_ADC_INJ_SEQ_SCAN_ENABLE_2RANKS;
//  ADC_INJ_InitStruct.SequencerDiscont = LL_ADC_INJ_SEQ_DISCONT_DISABLE;
//  ADC_INJ_InitStruct.TrigAuto = LL_ADC_INJ_TRIG_INDEPENDENT;
//  LL_ADC_INJ_Init(ADC1, &ADC_INJ_InitStruct);
//  LL_ADC_INJ_SetQueueMode(ADC1, LL_ADC_INJ_QUEUE_DISABLE);
//  LL_ADC_INJ_SetTriggerEdge(ADC1, LL_ADC_INJ_TRIG_EXT_RISING);
  /* Disable ADC deep power down (enabled by default after reset state) */
  LL_ADC_DisableDeepPowerDown(ADC1);
  /* Enable ADC internal voltage regulator */
  LL_ADC_EnableInternalRegulator(ADC1);
  /* Delay for ADC internal voltage regulator stabilization. */
  /* Compute number of CPU cycles to wait for, from delay in us. */
  /* Note: Variable divided by 2 to compensate partially */
  /* CPU processing cycles (depends on compilation optimization). */
  /* Note: If system core clock frequency is below 200kHz, wait time */
  /* is only a few CPU processing cycles. */
  uint32_t wait_loop_index;
  wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
  while(wait_loop_index != 0)
    wait_loop_index--;
  /** Configure Injected Channel
//  LL_ADC_INJ_SetSequencerRanks(ADC1, LL_ADC_INJ_RANK_1, LL_ADC_CHANNEL_3);
//  LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_3, LL_ADC_SAMPLINGTIME_12CYCLES_5);
//  LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_3, LL_ADC_SINGLE_ENDED);
//  /** Configure Injected Channel
//  LL_ADC_INJ_SetSequencerRanks(ADC1, LL_ADC_INJ_RANK_2, LL_ADC_CHANNEL_12);
//  LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_12, LL_ADC_SAMPLINGTIME_12CYCLES_5);
//  LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_12, LL_ADC_SINGLE_ENDED);
  /** Configure Regular Channel
  LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_1);
  LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_1, LL_ADC_SAMPLINGTIME_640CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_1, LL_ADC_SINGLE_ENDED);
  LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_2, LL_ADC_CHANNEL_TEMPSENSOR_ADC1);
  LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_TEMPSENSOR_ADC1, LL_ADC_SAMPLINGTIME_640CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_TEMPSENSOR_ADC1, LL_ADC_SINGLE_ENDED);
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC1), LL_ADC_PATH_INTERNAL_VREFINT|LL_ADC_PATH_INTERNAL_TEMPSENSOR);
  LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_3, LL_ADC_CHANNEL_VREFINT);
  LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_VREFINT, LL_ADC_SAMPLINGTIME_640CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_VREFINT, LL_ADC_SINGLE_ENDED);
  /* USER CODE BEGIN ADC1_Init 2 */
/* Enable interruption ADC group regular end of unitary conversion */
  LL_ADC_EnableIT_EOS(ADC1);
while(LL_ADC_IsEnabledIT_EOS(ADC1) == 0){}
LL_ADC_EnableIT_EOC(ADC1);
//LL_ADC_DisableIT_EOC(ADC1);
while(LL_ADC_IsEnabledIT_EOC(ADC1) == 0){} /* == 0 if Enabled*/
LL_ADC_DisableIT_EOSMP(ADC1);
  /* Enable interruption ADC group end of injected conversion */
  LL_ADC_EnableIT_JEOC(ADC1);
while(LL_ADC_IsEnabledIT_JEOC(ADC1) == 0){}
  LL_ADC_DisableIT_JEOS(ADC1);
while(LL_ADC_IsEnabledIT_JEOS(ADC1) != 0){}
  LL_ADC_StartCalibration(ADC1, LL_ADC_SINGLE_ENDED);
wait_loop_index = (ADC_DELAY_CALIB_ENABLE_CPU_CYCLES >> 1);
wait_loop_index--;
  /* USER CODE END ADC1_Init 2 */
/* ADC2 init function */
void MX_ADC2_Init(void)
  /* USER CODE BEGIN ADC2_Init 0 */
  /* USER CODE END ADC2_Init 0 */
  LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOC);
  /**ADC2 GPIO Configuration
  PA6   ------> ADC2_IN3
  PC4   ------> ADC2_IN5
  GPIO_InitStruct.Pin = V_CURRENT_Pin;
  LL_GPIO_Init(V_CURRENT_GPIO_Port, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = TEMP_SENS_1C4_Pin;
  LL_GPIO_Init(TEMP_SENS_1C4_GPIO_Port, &GPIO_InitStruct);
  /* ADC2 DMA Init */
  /* ADC2 Init */
  LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_2, LL_DMAMUX_REQ_ADC2);
  LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_2, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
  LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_2, LL_DMA_PRIORITY_MEDIUM);
  LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_2, LL_DMA_MODE_CIRCULAR);
  LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_2, LL_DMA_PERIPH_NOINCREMENT);
  LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_2, LL_DMA_MEMORY_INCREMENT);
  LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_2, LL_DMA_PDATAALIGN_HALFWORD);
  LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_2, LL_DMA_MDATAALIGN_HALFWORD);
  /* ADC2 interrupt Init */
  /* USER CODE BEGIN ADC2_Init 1 */
LL_DMA_ConfigAddresses(DMA1,LL_DMA_CHANNEL_2,LL_ADC_DMA_GetRegAddr(ADC2, LL_ADC_DMA_REG_REGULAR_DATA),
(uint32_t)Veriables_Analog.AdcVal.mosfetTemp,LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_SetDataLength(DMA1,LL_DMA_CHANNEL_2,1);
  LL_DMA_EnableIT_TC(DMA1,LL_DMA_CHANNEL_2);
  LL_DMA_EnableIT_TE(DMA1,LL_DMA_CHANNEL_2);
LL_DMA_EnableChannel(DMA1,LL_DMA_CHANNEL_2);
  /* USER CODE END ADC2_Init 1 */
  /** Common config
  LL_ADC_Init(ADC2, &ADC_InitStruct);
  ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
  LL_ADC_REG_Init(ADC2, &ADC_REG_InitStruct);
  LL_ADC_SetGainCompensation(ADC2, 0);
  LL_ADC_SetOverSamplingScope(ADC2, LL_ADC_OVS_DISABLE);
  ADC_INJ_InitStruct.SequencerLength = LL_ADC_INJ_SEQ_SCAN_DISABLE;
  LL_ADC_INJ_Init(ADC2, &ADC_INJ_InitStruct);
  LL_ADC_INJ_SetQueueMode(ADC2, LL_ADC_INJ_QUEUE_DISABLE);
  LL_ADC_INJ_SetTriggerEdge(ADC2, LL_ADC_INJ_TRIG_EXT_RISING);
  LL_ADC_DisableDeepPowerDown(ADC2);
  LL_ADC_EnableInternalRegulator(ADC2);
    wait_loop_index--;
  LL_ADC_INJ_SetSequencerRanks(ADC2, LL_ADC_INJ_RANK_1, LL_ADC_CHANNEL_3);
  LL_ADC_SetChannelSamplingTime(ADC2, LL_ADC_CHANNEL_3, LL_ADC_SAMPLINGTIME_12CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC2, LL_ADC_CHANNEL_3, LL_ADC_SINGLE_ENDED);
  LL_ADC_REG_SetSequencerRanks(ADC2, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_5);
  LL_ADC_SetChannelSamplingTime(ADC2, LL_ADC_CHANNEL_5, LL_ADC_SAMPLINGTIME_640CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC2, LL_ADC_CHANNEL_5, LL_ADC_SINGLE_ENDED);
  /* USER CODE BEGIN ADC2_Init 2 */
  LL_ADC_EnableIT_EOS(ADC2);
while(LL_ADC_IsEnabledIT_EOS(ADC2) == 0){}
  //LL_ADC_DisableIT_EOC(ADC2);
LL_ADC_EnableIT_EOC(ADC2);
while(LL_ADC_IsEnabledIT_EOC(ADC2) == 0){}
LL_ADC_DisableIT_EOSMP(ADC2);
  LL_ADC_EnableIT_JEOC(ADC2);
while(LL_ADC_IsEnabledIT_JEOC(ADC2) == 0){}
  LL_ADC_DisableIT_JEOS(ADC2);
while(LL_ADC_IsEnabledIT_JEOS(ADC2) != 0){}
LL_ADC_StartCalibration(ADC2, LL_ADC_SINGLE_ENDED);
/* Delay between ADC end of calibration and ADC enable.                   */
wait_loop_index--;
  /* USER CODE END ADC2_Init 2 */
void SystemManager_Start(void)
GD_Start();
Analog_Start();
LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH1);
  LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH1N);
  LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH2);
LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH2N);
  LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH3);
  LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH3N);
LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH4);
  LL_TIM_EnableAllOutputs(TIM1);
  /* Enable counter */
  LL_TIM_EnableCounter(TIM1);
while(LL_TIM_IsEnabledCounter(TIM1) == 0){}
TIM1->CCR1 = 0;
TIM1->CCR2 = 0;
TIM1->CCR3 = 0;
HAL_Delay(100);
LL_GPIO_SetOutputPin(GD_WAKE_GPIO_Port,GD_WAKE_Pin);
HAL_Delay(10);
void Analog_Start(void)
LL_ADC_ClearFlag_EOC(ADC1);
LL_ADC_ClearFlag_EOS(ADC1);
LL_ADC_ClearFlag_EOSMP(ADC1);
LL_ADC_ClearFlag_EOC(ADC2);
LL_ADC_ClearFlag_EOS(ADC2);
LL_ADC_ClearFlag_EOSMP(ADC2);
LL_ADC_ClearFlag_ADRDY(ADC1);
LL_ADC_ClearFlag_ADRDY(ADC2);
LL_ADC_Enable(ADC1);
LL_ADC_Enable(ADC2);
while(LL_ADC_IsActiveFlag_ADRDY(ADC1) && LL_ADC_IsActiveFlag_ADRDY(ADC2) !=1){}
while(LL_ADC_IsEnabled(ADC1) && LL_ADC_IsEnabled(ADC2) != 1){}
if((LL_ADC_REG_IsConversionOngoing(ADC1) || LL_ADC_REG_IsConversionOngoing(ADC2)) == 0){
LL_ADC_REG_StartConversion(ADC1);
LL_ADC_REG_StartConversion(ADC2);
arge2Best answer
Feb 6, 2025 2:51 PM UTC
Edit
SOLUTION: ADC has a strange sequencial start routine. If you do not obey its rule, it doesnt start conversion.
Procedure for Properly Starting ADC:
Enable_Internal_Regular();
Wait();
Start_Calibration();
Wait();
Check_ADC_RDY_and_Enabled_Flags();
Enable_ADC();
Wait();
Start_Conversion();
arge2AuthorBest answer
Edit
Wait();
Wait();
Enable_ADC();
Wait();
Start_Conversion();
