__Mohamed__Ayman__Dev
5 Hidden STM32 Features That Even Experienced Developers Miss
STM32 MCUs hide surprisingly useful hardware features that can save you CPU cycles, lower power, make multi-core life easier, and fix intermittent bugs — if you know they exist. This article reveals 5 “hidden” STM32 features (with concrete examples and code) that even experienced MCU engineers often forget, and exactly how to use them safely in production.
Feature 1 — Fast-mode Plus I²C (FM+, up to 1 MHz)
Fast-mode Plus (FM+) is an I²C mode that supports communication speeds up to 1 MHz, which is faster than Standard mode (100 kHz) and 2× faster than normal Fast-mode (400 kHz).
Why does FM+ exist?
Standard 400 kHz I²C couldn’t keep up with:
  • High-speed sensors
  • High-refresh displays
  • Real-time control loops
  • Large configuration registers in ICs
  • Interrupt-driven or polling-heavy systems
FM+ allows faster transfers without switching to SPI.
Why is FM+ “special” in STM32?
Most STM32 MCUs have:
  • Dedicated FM+ pins (because they need stronger current capability)
  • Hardware filters designed to support 1 MHz edges
  • Automatic glitch filtering updated for high-speed modes
Example:
PA11/PA12 on STM32F4 or PB6/PB7 on STM32G4 often support FM+.
Quick code hint (conceptual):
// Pseudocode: enable FM+ in SYSCFG (family-dependent)
SYSCFG->CFGR1 |= SYSCFG_CFGR1_I2C_FMP; // family-specific bit; check datasheet
// Then configure I2C timing for ~1MHz using CubeMX timing calculator or AN4235
Feature 2 — Hardware Semaphores (HSEM) — great for multi-core STM32
Hardware Semaphores are special hardware registers that act like locks.
Two cores (e.g., Cortex-M7 and Cortex-M4 in STM32H7) can use these locks to coordinate access to:
  • Shared peripherals
  • Shared RAM regions
  • Shared communication buffers
  • Shared interrupt events
  • Boot coordination
This prevents race conditions and makes multi-core programming reliable.
Why do we need Hardware Semaphores?
In dual-core STM32 MCUs:
  • Both cores can read/write memory
  • Both cores can access I²C, SPI, GPIO
  • Both cores can modify shared buffers
Without protection, both cores may:
  • Write to the same memory at the same time
  • Configure a peripheral at the same time
  • Interrupt each other unexpectedly
  • Cause corrupted data, freezes, or hard faults
A hardware semaphore ensures that only ONE core owns a resource at a time.
Example Pattern:
// take: write 0x1 to HSEM_SEMIDx to lock if free
if (HSEM->RLR[semid] == 0) {
 HSEM->R[semid] = LOCK_VALUE; // 2-step or 1-step lock depends on family
Feature 3 — Burst DMA
Burst DMA means the DMA controller transfers multiple data items in one go (a burst) instead of transferring them one-by-one.
Why bursts are faster?
Because each DMA transfer requires:
  • an address fetch
  • a bus request
  • a bus arbitration
  • a memory access
A burst packs many of these into one bus transaction.
Typical burst sizes:
  • Single (1 beat)
  • INCR4 (4 beats)
  • INCR8 (8 beats)
  • INCR16 (16 beats)
Benefits:
  • Higher memory bandwidth
  • Lower bus overhead
  • Perfect for high-speed peripherals
  • Reduces CPU contention on the AHB/AXI bus
When to use Burst DMA?
  • Large data arrays
  • Audio buffers
  • Image frames
  • ADC multi-channel sequences
  • SPI/I2S streaming
  • Memory-to-memory copies
Feature 4 — DMA FIFO Mode
FIFO = First-In-First-Out buffer inside the DMA (up to 4 words depth, depending on MCU).
The FIFO acts like a mini-cache, allowing the DMA to:
  • accumulate data before writing
  • pack bursts more efficiently
  • avoid misaligned transfers
  • avoid bus stalls
  • adapt to different memory widths
Modes:
  • Direct mode (FIFO disabled)
  • FIFO mode enabled
    • FIFO threshold: ¼, ½, ¾, full
Why FIFO is useful?
Because without it, the DMA must transfer each element immediately — inefficient for:
  • different source/destination widths (e.g., 8→32 bit)
  • slow peripheral buses
  • high burst rates
FIFO example:
ADC outputs 16-bit.
Memory needs 32-bit aligned writes.
Without FIFO → problems.
With FIFO → DMA packs data correctly and efficiently.
Feature 5 — Double-Buffer Mode (Ping-Pong Mode)
Double-buffer mode allows DMA to use two memory buffers:
  • Buffer A
  • Buffer B
While DMA is filling one buffer, the CPU can process the other.
This solves a major real-time problem:
no data loss during processing.
Perfect for:
  • Audio or voice streaming
  • Continuous ADC sampling
  • UART RX with high throughput
  • Real-time DSP
  • High-speed USB
  • Camera or video frame capture
Example:
  • DMA fills Buffer A
  • CPU processes Buffer B
  • DMA finishes → buffer swap
  • CPU now processes A
  • DMA now fills B
This is called ping-pong or circular double-buffering.
How these 3 features work together
The most powerful DMA setup is:
Burst + FIFO + Double-buffer
Example use cases:
  • High-speed ADC sampling → DSP pipeline
  • Ethernet RX/TX descriptors
  • I2S audio codec
  • SPI display streaming
  • Camera interface (DCMI)
Data moves:
  1. Double-buffer mode ensures no pauses or data loss
  2. FIFO mode ensures bus efficiency and alignment
  3. Burst mode ensures maximum throughput
