Pintoo
What is the temperature range of the nucleo-u575zi-q evaluation board ?
  • December 3, 2021
  • 4 replies
  • 1495 views
my goal is to use this board in [-40°C +85°C] climatic chamber.
Regards:)
Oliver
Best answer by TDK
The boards are meant for evaluation in a lab bench type environment. I don't think they're rated for a temperature range, but should work in the industrial temp range (-40 to +85) provided you keep humidity from condensing. Certainly the chip itself will work in this range. Might want to check the temp range of the crystal on the board if you're using it for a clock source.
TDKBest answer
December 3, 2021
Pintoo
PintooAuthor
According your answer, to check the component's temperature, where can I find the Bill Of Materials for the nucleo-u575zi-q evaluation board ?
If you go to the product page, you can find the design files, including the BOM, under "CAD Resources":
https://www.st.com/en/evaluation-tools/nucleo-u575zi-q.html#cad-resources
https://www.st.com/resource/en/bill_of_materials/mb1549_bom.zip
Pintoo
PintooAuthor
Thank you TDK, I'm going to check the BOM to retrieve the operationnal temperature of the evaluation board Nucleo 144
