Uwe Bonnes
Chief
December 10, 2018
What is the status of STLINKV3 on USB3 ports on Linux?
  • December 10, 2018
  • 3 replies
  • 964 views
discussed in earlier threads, STLINKV3 does not appear on USB3 ports on Linux. It does appear on the same physical machine when run on a virtual machine with Virtualbox. Has this problem been realized by the developpers? Is there any solution to expect in a sensible time frame?
HermannKleier
Short answer: I’m using it under Debian 9.6.
Longer answer:
  • Compile and install a recent version of OpenOCD
  • Disconnect the on-board ST-Link/V2-1
  • Connect the ST-Link/V3
  • Set up udev-rules
  • Create a project-specific OpenOCD configuration
and enjoy. You’ll find the gory details at https://mbd.kleier.net/integrating-st-link-v3.html.
Uwe Bonnes
Chief
January 2, 2019
Okay, my question was not clear. I meant "appear" in STM32CubeProg!
HermannKleier
Okay. I just wanted to bolster you up. ☺ Because it is kind of working just now, it can be expected to be integrated into higher environments soon. But, to be honest, there is way to go to reach a comfortable environment. And we require a small shield to connect a power supply and the external ST-Link/V3.
