TSrin
What is the CLI command to disconnect the target?
I want to connect multiple target for programming one by one. When one of target is connected, couldn't disconnect through CLI command to connect the next one.
turboscrew
Senior III
December 28, 2018
I did something like that about half a year ago, and I vaguely recall, that with CLI you don't disconnect.
I think "connect" only sets up some (shell?) variables, so the ST-link remembers which devices it was involved last. You just connect to new device (via new POD, if needed).
TSrin
TSrinAuthor
Thanks @turboscrew. This helped. I'm connecting the second target with new shell.
