PHolt.1
Senior
July 21, 2021
What has changed in Cube IDE v1.7?
I have frozen my project on v1.6.1, for good reasons because I don't want new libraries; the existing ones are already massively bloated and full of bugs :)
Have they fixed bugs like
  • cannot delete the .elf file (the STLINK debugger is grabbing it - already posted here)
  • frequently, a Project clean/Build has to be done when files are edited externally
Release notes:
https://www.st.com/resource/en/release_note/dm00603738-stm32cubeide-release-v161-stmicroelectronics.pdf
(Despite the filename, this contains the v1.7.0 release notes.)
PHolt.1
PHolt.1Author
Senior
July 21, 2021
They don't list the above bugs.
There is another bug, reproduced across very different hardware: during compilation, a lot of the console output is missing, and it looks like it is generated using a white font! The text is there because if you swipe the blank space and copy/paste into say Notepad, you see the text.
