Tajwar.Chandel
We are using STM32H743ZIT6 MCU , but i am unable to connect the STlink-V3SET LKV3SET$AT3 Programmer with our device target but still facing the error "Target no device found". Kindly help and guide. Same activity is done on 2-3 different device , but
Hello @Tajwar.Chandel​ ,
Did you try with STM32Cubeprogrammer?
Try changing the USB cables.
Check the jumpers configuration following this UM2189.
Try connecting with mode 'under reset'.
Imen
Tajwar.Chandel
Hi Imen,
Thanks for the reply. I have tried after replace the micro USB cable. But still failed. I have traying to connect with STlink-V3Set. Result target no device found. When i connect the same target with Nucleo ST link then its connected. Why ? I just want to know why its is not connected with STLINK-V3SET debugger.
If our hardware was faulty then the device could not connect with Nucleo-ST link.
Kindly respond.
Regards,
Tajwar
Mob. +91 9857325411
April 7, 2023
Show how physically connected.​
