rokasjsutkus
Using the st-link CLI
Posted on November 16, 2016 at 10:18
Hey,
After entering anything to the command line, it just goes off, doesn't do anything, tried different combinations, commands, anything, but it just exits and nothing. Dis anyone had similar problems, or knows whats wrong, or tell me that I'm using it wrong.
Thanks in advance.
#st-link-cli
slimen
November 16, 2016
Posted on November 16, 2016 at 12:00
Which ST_LINK_CLI version are you using?
Have a look to the STM32 ST-LINK utility command line interface (CLI) section in the
http://http://www.st.com/content/ccc/resource/technical/document/user_manual/e6/10/d8/80/d6/1d/4a/f2/CD00262073.pdf/files/CD00262073.pdf/jcr:content/translations/en.CD00262073.pdf
User manual. Hope this helps you.
rokasjsutkus
Posted on November 17, 2016 at 13:01
The version is 2.5.0
I have read the manual, but it doesn't mention anything about the CLI closing it self just by writing a command, or anything at all.
rokasjsutkus
Posted on November 17, 2016 at 13:47
Problem solved, reinstalled the software, now it works fine.
