EC.3
USB host application based on the Audio IN class
I've seen other posts provide links to examples for "USB host application based on the Audio OUT class". Are there any for audio in?
STTwo-32
Hello @EC.3
I suggest you to take a look at the X-CUBE-USB-AUDIO And try to adapt it to your MCU and project.
Best Regards.
STTwo-32
EC.3
EC.3Author
Hi @STTwo-32 ,
I've been looking at that too, although the examples it contains are for USB Device rather than Host. I'm going to see if I can mix, match and adapt with what I've come across so far, but I'll keep this ticket open a bit longer just to see if anyone happens to know of a more closely aligned example.
