UART doesn't work on STM32F407G-DISC1
Hello
I'am new to STM32 and i want to create project that interface with user using uart with serial monitor
i  configured usart and used hal_uart tarsnmit function but it didnt work when the tutorial im following worked for him
what can be the issue?
Gyessine
GyessineBest answer
Hello @avatar_ang  and welcome to STcommunity!
can you explain how are you trying to print your messages  in serial monitor?
in the STM32F407G-DISC1 ,the ST-Link embedded in the F407 discovery is not wired to a target MCU UART, so it has no virtual COMPORT capability.(the physical connection is missing.) you will need to add physical link wires to the Discovery board or connect to a separate USB-to-UART adaptor.
Maybe this is your issue.
If this isn't your issue , please provide more informations
BR
Gyessine
gbm
What kind of help you expect without providing any code or schematic?
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
Gyessine
GyessineBest answer
BR
Gyessine
Andrew Neil
It does have the VCP (Virtual COM Port) capability in the ST-Link itself - it just lacks the physical connection from the ST-Link to the F407 Target MCU
Andrew Neil
Welcome to the forum.
As @gbm says, it helps to give more details about your situation - see:
How to write your question to maximize your chances to find a solution
@avatar_ang wrote:
 it didn't work when the tutorial I'm following worked for him
Was that tutorial specifically for the STM32F407G-DISC1 board?
Please also post a link to that tutorial.
What "serial monitor" are you using?
thanks for mentioning the USB to UART converter we used one and it worked
