Trouble with X-CUBE-ST67W61M1 with X-NUCLEO-U545RE-Q
I am trying to use X-CUBE-ST67W61M1 but I am failing to read any data with COM port set as document um3449 indicates (I am currently using a UART-TTL converter connected on CN7 of X-NUCLEO-ST67W61M1). I am trying to update the X-NUCLEO-ST67W61M1 firmware to see if anything changes, but NCP_update_mission_profile.bat from X-CUBE-ST67W61 does not support update with my Nucleo board. Are there any ways to bypass this problem?
Moreover, any ideas about why I am not reading anything sensible from the X-NUCLEO-ST67W61M1 UART port?
Thanks in advance for any advice
