NKuma.20
TouchGFX for STM32H750B DK Board
  • July 8, 2024
  • 1302 views
I'm trying to build up a GUI using TouchGFX for STM32H750B-DK board using the external memory but unable to get anything on screen. Can anybody share the any details or links for the same ?
I'm attaching the files for reference. If somebody can guide whats the error in it ?
below is the linker.id code:
**  File        : LinkerScript.ld
**  Author : Auto-generated by STM32CubeIDE
**  Abstract    : Linker script for STM32F746G-DISCO Board embedding STM32F746NGHx Device from STM32F7 series
**                      1024Kbytes FLASH
**                      320Kbytes RAM
**                Set heap size, stack size and stack location according
**                to application requirements.
**                Set memory bank area and size if external memory is used.
**  Target      : STMicroelectronics STM32
**  Distribution: The file is distributed as is without any warranty
**                of any kind.
** @attention
** <h2><center>&copy; COPYRIGHT(c) 2020 STMicroelectronics</center></h2>
** Redistribution and use in source and binary forms, with or without modification,
** are permitted provided that the following conditions are met:
**   1. Redistributions of source code must retain the above copyright notice,
**      this list of conditions and the following disclaimer.
**   2. Redistributions in binary form must reproduce the above copyright notice,
**      this list of conditions and the following disclaimer in the documentation
**      and/or other materials provided with the distribution.
**   3. Neither the name of STMicroelectronics nor the names of its contributors
**      may be used to endorse or promote products derived from this software
**      without specific prior written permission.
** THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
** AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
** IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
** DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
** FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
** DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
** SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
** CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
** OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
** OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM) + LENGTH(RAM); /* end of "RAM" Ram type memory */
_Min_Heap_Size = 0x200 ; /* required amount of heap  */
_Min_Stack_Size = 0x400 ; /* required amount of stack */
/* Memories definition */
MEMORY
  RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 320K
  FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
  QUADSPI (rx)  : ORIGIN = 0x90000000,  LENGTH = 16M
/* Sections */
SECTIONS
  /* The startup code into "FLASH" Rom type memory */
  .isr_vector :
    . = ALIGN(4);
    KEEP(*(.isr_vector)) /* Startup code */
    . = ALIGN(4);
  } >FLASH
  /* The program code and other data into "FLASH" Rom type memory */
  .text :
    . = ALIGN(4);
    *(.text)           /* .text sections (code) */
    *(.text*)          /* .text* sections (code) */
    *(.glue_7)         /* glue arm to thumb code */
    *(.glue_7t)        /* glue thumb to arm code */
    *(.eh_frame)
    KEEP (*(.init))
    KEEP (*(.fini))
    . = ALIGN(4);
    _etext = .;        /* define a global symbols at end of code */
  } >FLASH
  /* Constant data into "FLASH" Rom type memory */
  .rodata :
    . = ALIGN(4);
    *(.rodata)         /* .rodata sections (constants, strings, etc.) */
    *(.rodata*)        /* .rodata* sections (constants, strings, etc.) */
    . = ALIGN(4);
  } >FLASH
  .ARM.extab   : {
    . = ALIGN(4);
    *(.ARM.extab* .gnu.linkonce.armextab.*)
    . = ALIGN(4);
  } >FLASH
  .ARM : {
    . = ALIGN(4);
    __exidx_start = .;
    *(.ARM.exidx*)
    __exidx_end = .;
    . = ALIGN(4);
  } >FLASH
  .preinit_array     :
    . = ALIGN(4);
    PROVIDE_HIDDEN (__preinit_array_start = .);
    KEEP (*(.preinit_array*))
    PROVIDE_HIDDEN (__preinit_array_end = .);
    . = ALIGN(4);
  } >FLASH
  .init_array :
    . = ALIGN(4);
    PROVIDE_HIDDEN (__init_array_start = .);
    KEEP (*(SORT(.init_array.*)))
    KEEP (*(.init_array*))
    PROVIDE_HIDDEN (__init_array_end = .);
    . = ALIGN(4);
  } >FLASH
  .fini_array :
    . = ALIGN(4);
    PROVIDE_HIDDEN (__fini_array_start = .);
    KEEP (*(SORT(.fini_array.*)))
    KEEP (*(.fini_array*))
    PROVIDE_HIDDEN (__fini_array_end = .);
    . = ALIGN(4);
  } >FLASH
  ExtFlashSection :
*(ExtFlashSection ExtFlashSection.*)
*(.gnu.linkonce.r.*)
    . = ALIGN(0x4);
  } >QUADSPI
  /* Used by the startup to initialize data */
  _sidata = LOADADDR(.data);
  /* Initialized data sections into "RAM" Ram type memory */
  .data :
    . = ALIGN(4);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    . = ALIGN(4);
    _edata = .;        /* define a global symbol at data end */
  } >RAM AT> FLASH
  /* Uninitialized data section into "RAM" Ram type memory */
  . = ALIGN(4);
  .bss :
    /* This is used by the startup in order to initialize the .bss section */
    _sbss = .;         /* define a global symbol at bss start */
    __bss_start__ = _sbss;
    *(.bss)
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;         /* define a global symbol at bss end */
    __bss_end__ = _ebss;
  } >RAM
  /* User_heap_stack section, used to check that there is enough "RAM" Ram  type memory left */
  ._user_heap_stack :
    . = ALIGN(8);
    PROVIDE ( end = . );
    PROVIDE ( _end = . );
    . = . + _Min_Heap_Size;
    . = . + _Min_Stack_Size;
    . = ALIGN(8);
  } >RAM
  /* Remove information from the compiler libraries */
  /DISCARD/ :
    libc.a ( * )
    libm.a ( * )
    libgcc.a ( * )
  .ARM.attributes 0 : { *(.ARM.attributes) }
/* Un comment this section to place fonts and text in external flash */
  FontFlashSection :
*(FontFlashSection FontFlashSection.*)
        . = ALIGN(0x4);
} >QUADSPI
  TextFlashSection :
*(TextFlashSection TextFlashSection.*)
        . = ALIGN(0x4);
} >QUADSPI
NKuma.20
NKuma.20Author
Refer to the current attached files. When running the following files I'm getting just a black screen on the display.
What could be the issue in it ?
Below is the code for linked.id file:
**  Abstract    : Linker script for STM32H7 series
**                128Kbytes FLASH and 1056Kbytes RAM
**                of any kind.
** @attention
/* Entry Point */
MEMORY
  RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
  FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 128K
  QUADSPI (rx)  : ORIGIN = 0x90000000,  LENGTH = 128M
/* Sections */
SECTIONS
  .isr_vector :
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  .text :
    . = ALIGN(4);
    *(.eh_frame)
    KEEP (*(.init))
    KEEP (*(.fini))
    . = ALIGN(4);
  } >FLASH
  .rodata :
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  .ARM.extab   : {
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  .ARM : {
    . = ALIGN(4);
    __exidx_start = .;
    *(.ARM.exidx*)
    __exidx_end = .;
    . = ALIGN(4);
  } >FLASH
  .preinit_array     :
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  .init_array :
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  .fini_array :
    . = ALIGN(4);
    . = ALIGN(4);
  } >FLASH
  ExtFlashSection :
    . = ALIGN(0x4);
  } >QUADSPI
  .data :
    . = ALIGN(4);
    . = ALIGN(4);
  } >RAM AT> FLASH
  . = ALIGN(4);
  .bss :
    *(.bss)
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
  } >RAM
  ._user_heap_stack :
    . = ALIGN(8);
    . = ALIGN(8);
  } >RAM
  /DISCARD/ :
    libc.a ( * )
    libm.a ( * )
    libgcc.a ( * )
  FontFlashSection :
        . = ALIGN(0x4);
} >QUADSPI
  TextFlashSection :
        . = ALIGN(0x4);
} >QUADSPI
KDJEM.1
Hello @NKuma.20 ,
Could you please refer to TouchCFX demonstration in STM32Cube_FW_H7_1.11.2 package under this path  "Repository\STM32Cube_FW_H7_V1.11.2\Projects\STM32H750B-DK\Demonstrations\TouchGFX" and check the linker.
I hope this help you.
Kaouthar
