Domenico
STM32U5 B-U585I-IOT02A unable to connect to device after TrustZone example execution
I have run the example code STM32Cube_FW_U5_V1.1.1\Projects\B-U585I-IOT02A\Examples\GPIOGPIO_IOToggle_TrustZone and I can no longer connect to the B-U585I-IOT02A board via STM32CubeProgrammer to disable TrustZone. I have the ST-LINK error message (DEV_TARGET_NOT_HALTED).
Thank you
Imen.DBest answer
Hello @Domenico​
Firstly, check your USB cable, connectors, and try connect in "under reset" mode.
Try boot on RSS : BOOT0 pin PH3 to VDD, as described in the AN5347.
Make sure to use latest release of CubeProgrammer.
Imen
Imen.DBest answer
Hello @Domenico​
Imen
Domenico
DomenicoAuthor
Hi @Imen DAHMEN​,
I solved the problem with boot on RSS.
