lgoti
January 16, 2020
STM32L071 Programming error @: 0x08080C08
Hello
When I use ST link utility for programming STM32L071 error occur when it starts to program EEPROM. Each time first 8 bytes are programmed correctly and after that an error occur. After that it's not possible to change EEPROM bytes manually from ST link utility.
When i program microcontroller from keil everything is programmed correctly, and when i use STM32L053 there is no problem with st link utility.
Does anyone know what could be a problem?
tnx
