Jul 17, 2025 3:44 PM UTC
STM32H757I-EVAL MB1166-Default-A08 Display Controller
I have STM32H757I-EVAL board which has MB1166 Rev A LCD daughter board. I tried to find which display controller is used with this LCD display.
I had gone through the MB1166 schematics which shows 2 options
 1. KM-040TMP-02
 2. FRD397B2509
I got confused which one to consider.
And I found different in example code which is OTM8009A.
Which display driver used exactly in this board?
Thanks,
Satheesh
QSHAO.1
QSHAO.1Best answer
Jul 18, 2025 2:52 AM UTC
Both LCD modules of KM-040TMP-02 and FRD397B2509 with same LCD driver IC OTM8009A. so that why you saw OTM8009A in LCD driver code. Based on board history in UM2525, MB1166-Default-A08 BOM is used for STM32H757I-EVAL, based on MB1166-A08 BOM, FRD397B25009 is used on the board.
QSHAO.1
QSHAO.1Best answer
Jul 18, 2025 6:53 AM UTC
Thank you so much for the replay.
Jul 18, 2025 4:03 PM UTC
I have installed STM32CubeIDE v1.14.0 and I have STM32H757I-EVAL board.
I'm unable to find example projects (LCD DSI) for this board in IDE. Instead, I can find LCD DSI example projects for STM32H747I-EVAL board.
Can we run example projects defined for board h747 on h757?
I cannot upgrade my IDE version as my existing projects restricting.
