elb-lab
STM32G431KBT6 SHort-Circuit on VDDA
I made two projects using the new 36-pin STM32G431KBT. In both projects, after a few seconds of 3.2 Volt power supply, the VDDA pin is short-circuited with the VSS / VSSA pin definitively. As many as 5 chips broke this way. Is it a manufacturing defect?
Thank you
August 11, 2019
On the balance of probabilities, likely some current paths or voltage differential on your design.
