Apr 14, 2025 11:18 AM UTC
STM32G0B1CET6N Eval Board.
We have been using this Processor for very long time in our 2 project stream.
We are planning to use this part again, but for application suitability we need to verify this product as per our requirement.
So, i wanted to ask is there any Evaluation board available for this part, STM32G0B1CET6N
Andrew Neil
Andrew NeilBest answer
Apr 14, 2025 11:44 AM UTC
As always, go to the Product Page, and look on the 'Tools & Software' tab - there you will find available boards listed:
https://www.st.com/en/microcontrollers-microprocessors/stm32g0b1ce.html#tools-software
But this is strange:
If you've already been using it for "a very long time" - why do you need to "verify" it now?
mƎALLEm
Apr 14, 2025 11:26 AM UTC
You can use STM32CubeMx and select Access to the board:
And type "STM32G0":
These are the available boards for G0 product:
So No EVAL board available for this exact part number but only Nucleo board:
 STM32G0B1CE is a 48pin package while the Nucleo board is a 64 pin package. You can use it and adapt it later to your application. Both part numbers yours and on the on eon the Nucleo board have 512kB of flash.
Hope that helps.
Andrew Neil
