MFail.11
STM32F769I-EVAL 3D file or CAD
  • September 11, 2025
  • 682 views
I'm working on a daughter board to connect with STM32F769I-EVAL, no problem if it is obsolete.
I can't find good CAD resources for the item, I need a step 3D file or a pdf with the position and the height of all components, so I can design my board with a proper placement of components, without the risk to touch something.
I have only found the positions of the four connectors, but this is not enough, there are lots of thick elements around.
How can I get support for cad resources of this board?
Thanks,
Best answer by mƎALLEm
The only CAD resources for that board are available on that link:
https://www.st.com/en/evaluation-tools/stm32f769i-eval.html#cad-resources
Andrew Neil
Not sure that ST have that level of detail?
As the name suggests, the boards are just intended for development/evaluation - not for incorporating into a final product.
PS:
The BoM and Gerbers are available - you could work from there ... ?
mƎALLEm
mƎALLEmBest answer
