hashtala
STM32F767 External Oscillator input Pins input capacitance
Hello
I want to include Crystal Oscillator in my project with STM32F767
According to CubeMX HSE pins are PH0 and PH1.
when it comes to determining values of loading capacitors datasheet suggests that input capacitance must be takes into consideration. However I cannot find anything about that in datasheet.
Could you please give me clues to where to find input capacitance of PH0 and PH1 ?
waclawek.jan
It's not exact, but use the I/O pin capacitance value from I/O static characteristics table, usually 5pF.
hashtala
hashtalaAuthor
so 10pf or 15pf should be okay right ?
waclawek.jan
What's wrong with accepting 5pF?
hashtala
hashtalaAuthor
manufacturer of the oscillator I use required me that I use double the load capacitance. So since I am accepting your answer and taking copper trace's capacitance into account the most reasonable is 10pf (12 would be better but it is not available at local store)
Amel NASRI
Look to AN2867.
