STM32F746G: PCM-PWM and PWM-TDM tone generation
STM32F746G - will this MCU support for tone generation using PCM-PWM and PCM-TDM. Where i can get the refernece manual for this mcu.
mƎALLEm
mƎALLEmBest answer
Hello @AMS12345 ,
According to the reference manual, these are the Audio format supported by SAI interface in STM32F746:
STTwo-32
Hello @AMS12345 and welcome to the ST Community :smiling_face_with_smiling_eyes:.
The reference manual of this MCU is the RM0385.
Best Regards.
STTwo-32
AMS12345Author
Thanks for the reply @STTwo-32. Could you able to say that this board is flexible for generating tones for single channel and multiple channel using pwm peripheral, pcm peripheral and TDM peripheral.
mƎALLEm
mƎALLEmBest answer
Hello @AMS12345 ,
AMS12345Author
@mƎALLEm  can you suggest me the microcontroller that supports PCM-PWM to generate tones without any audio interfaces like I2S, SAI, DAC or om other. With my frequency need to genearte pcm samples and fed to pwm to generate audio as output.
mƎALLEm
PCM-PWM can be generated by any GP timer having PWM output.
