aatif shaikh
STM32f207's MII with Marvel's MII
Hi All,
     I'm developing a project, in which I've connected the MII port of STM32F207 with Marvel IC 88E6060 (Ethernet + fiber switch) MII port 5 but the firmware support (SPL for STM32F2XX) provides libraries for DP83848 PHY only.
     Hence, if I want to write a code to do MAC to PHY communication (STM <-> Marvel's Port 5 as a PHY) , how do I proceed ?
https://www.marvell.com/switching/assets/marvell_linkstreet_88E6060_datasheet.pdf
Did you find a solution. I am also faced with a similar problem with marvel switch. Could not find any example code . If you have please share.
